Greetings, I have a question about using torque control mode
I have a simple setup, a motor is driving load in torque control mode
I do the following
- from stationery position I drive the load with a constant torque, velocity goes up
- after a certain period of time I change the torque to the opposite with the same magnitude
what I observe is that the torque in the braking direction is weaker than the drive direction, is it limited somewhere? if so can we remove this limit, I can operate from a batter and it can absorb any amount of energy
thanks
