Torque @ max rpm and duty cycle for D5065
I want to use a D5065 for a setup that needs 8000 rpm @ 1.99 Nm (max torque in the datasheet).
I have two questions:
  1. I see in the datasheet a graph (Torque derating). What does this exactly mean/show? Does it mean that with forced cooling you can get max torque at 75% of the speed… or does it show a duty cycle?
  2. Would it be possible to run the motor continuesly with forced cooling at 8000 rpm with max torque or is there a duty cycle?
Thx,
Jeroen
8000rprm at 7 pole pairs is 933 hz, that is significantly above the max ODrive 3.x speed of ~ 600Hz. I doubt you’ll be able to achieve this.
There’s a couple forum posts where people have tested the achievable continuous torque on the D5065. A forum search should bring them up
thx wetmelon for the reply. That is good to know. I only looked at the RPM specs of the motor…
I searched and found some topics about heat but not specific for torque at max speed. If you could point me to one would appreciate it.
Could you recommend a motor and controller that could meet my specs? Or would a better option be to go with a gearbox to increase the RPM’s
thx!
@I-Connect I just ran into the torque derating curve and posted a detailed topic here if you’re still looking for info.
