SetVelocity(0, 0); seems to act like hold position when control mode is set to CONTROL_MODE_VELOCITY_CONTROL.
I expected that setting velocity to 0 will block the motors, but it does more than that.
If I try to move the motor manually, the motor will return to the position before the manual move. This is hold position!
Is this the normal behaviour?
Below is a test code in Arduino.
I can send commands (f for forward, z for stop) from Serial.
#define s_version "M.2025.07.17.0"
#include <HardwareSerial.h>
#include <SoftwareSerial.h>
#include <ODriveArduino.h>
template<class T> inline Print& operator <<(Print &obj,     T arg) { obj.print(arg);    return obj; }
template<>        inline Print& operator <<(Print &obj, float arg) { obj.print(arg, 4); return obj; }
// ODRIVE variables
HardwareSerial& odrive_serial = Serial1;
ODriveArduino odrive(odrive_serial);
void setup() {
  Serial.begin(115200);
  while (!Serial) {
    // some boards need to wait to ensure access to serial over USB
  Serial.print("Version: ");
  Serial.println(s_version);
  Serial.println("Connecting to ODrive ...");
  odrive_serial.begin(115200);
  while (!odrive_serial) {
  Serial.println("ODrive alive ...");
  for (int m = 0; m < 2; ++m) {
      int requested_state = AXIS_STATE_IDLE;
      Serial << "Axis" << m << ": Requesting state " << requested_state << '\n';
      if(!odrive.run_state(m, requested_state, false /*don't wait*/))
        return;
      odrive_serial << "w axis" << m << ".controller.config.input_mode " << INPUT_MODE_PASSTHROUGH << '\n';
      odrive_serial << "w axis" << m << ".controller.config.control_mode " << CONTROL_MODE_VELOCITY_CONTROL << '\n';
      odrive_serial << "w axis" << m << ".controller.config.vel_limit " << 3.0 << '\n';
      odrive_serial << "w axis" << m << ".motor.config.current_lim " << 30.0f << '\n';
void loop()
  if (Serial.available()){
    char c = Serial.read();
    if (c =='f'){// go forward
      int requested_state = AXIS_STATE_CLOSED_LOOP_CONTROL;
      Serial << "Axis" << 0 << ": Requesting state " << requested_state << '\n';
      if(!odrive.run_state(0, requested_state, false /*don't wait*/)) return;
      odrive.SetVelocity(0, 1.0);
      if(!odrive.run_state(1, requested_state, false /*don't wait*/)) return;
      odrive.SetVelocity(1, 1.0);
    else
    if (c =='z'){// stop
      odrive.SetVelocity(0, 0);
      odrive.SetVelocity(1, 0);
    else
    if (c =='c'){// clear errors
      odrive_serial << "sc\n";
    else
      Serial << "Invalid command " << c << '\n';
// read control mode
    odrive_serial << "r axis" << m << ".controller.config.control_mode\n";
    Serial << "Control mode of axis" << m << " " << odrive.readInt() << '\n';
  Serial.println(" ");
  delay (100);
