I use a 3.6 Odrive and an esp32 to control it.
I am able to use a lot of commande and allmost whatever I want.
But the issue come when I try to use fonctions, the odrive simply don’t take it.
here it work but when I try to use this one it don’t:
odrv0.axis0.encoder.set_linear_count(0) (over USB It work as I want)
any idea to use this function
I believe that right now we don’t support calling functions over ASCII, but I’ll check in on that. You might try just running w axis0.encoder.set_linear_count 0
THX for the answer
I tried but it don’t work, and yes I had see that ascii don’t support it but I can’t remember where.Is there any other way to reset the coder count without having the motor runnig?
thank
