Hi , when i make the calibration the motor makes beep and make slow rotation both directions (calibration) all is ok ,but When I apply force to rotate motor by hand the voltage increase!! Is normal?
Yes, your motor is a generator when it’s being driven.
Hi! Thanks for you answer, my voltage increase of the 18v to 24v volt quickly ,is dangerous for my odrive board?
The ODrive can handle up to 25V on a 24V board. Make sure you have your brake resistor plugged in!
