Your spot on in that the KV of the motor determines the maximum RPM you can choose.
kV is a physical property of the motor. A higher Kv will mean that a smaller voltage is induced in the stator windings by the rotor when you spin the motor than for an equivalent lower Kv motor. The KV rating of a motor is just as important for odrive as for any other motor controller as it determines the maximum speed that the motor can rotate for a given supply voltage while also being a good indicator of the motor torque produced for a given current. See this post for the KV to motor torque relationship.
