what is the brake command for this kind of motors in Odrive? i couldn’t find in document.
thanks all.
thanks all.
i solved it with high pos_gain values. i was set it to 10.
ODrive will automatically brake up to your current_limit if it’s in position or velocity control modes. In current control mode, you will have to manually set the braking torque by setting a current with opposite sign
