Hello! I’m so sorry, but I cannot find the rated amperage of the J2 5vdc pin. If someone in the know could direct me to documentation, or just knows how much power this pin can deliver, could you please let me know? Thank you so much, Christian
The 5V power supply on the ODrive 3.6 is provided by one DRV8301 chip and is rated for about 2A iirc as per its datasheet.
For external supplies, you should use no more than 1.5A. (worst case, i’d guess 0.5A could be needed by the ODrive itself)
