I am working on a project which uses a 48 volt 800 w motor .
I a very new to using odrive and am currently evaluating the board to check whether it suits our need. I am using this to develop an autonomous robot . I tried following the suggested documentation for hover board (cause motor is hall sensor based) but was not able to move the motor. I hear a beep sound and it moves for 5 sec when i run on sensor less mode. Also when i try to calibrate the sensor it does it. no error shown when dump_errors command is given.
Please help me with the process.
Regards,
Sumeet Shekhar
Assistant Manager,
R&D,
TVS motor Company,
Bengaluru, India. sumeet.shekhar@tvsmotor.com
Thanks so much for the recommendation. I tried that several times yet did not worked.
Is it that Odrive are not compatible with 48 volt 800 W bldc hub motors?
Also can you let me know which parameters in hoverboard guide are to be replaced by my motor parameter!
Thank you!
