I tried updating the firmware on the odrive using some custom firmware and then I tried “odrivetool dfu”.
but I get an overvoltage error if its above 24v, which leads me to believe the firmware was generated for the 24v version. I already tried changing the tup.config file to the 48v version with no luck.’
- Make sure tup.config is set correctly (you did this, good)
- run
make clean, then build again, just in case - flash this version
- in odrivetool run
erase_configuration(), thenreboot(). I think this is the most likely reason: the dc_bus_overvoltage config got saved from the previous firmware. - check again.
