Adding support for another SPI absolute encoder
Looks like the sensorless isn’t made for type 2 motors, we tried another one today (with an even higher resistance) and it would trigger errors where the bigger gimbal motor would not.
Luckily I found a way to make the new absolute encoder fit mechanically with an AMT102-V, so tomorrow we should be able to fine tune the custom encoder alignment after which we can start testing of the modified firmware.
Can we add two SPI encoders using the devel branch firmware?
Currently the RC0.5 has initial Absolute support for two different SPI encoders.
@Wetmelon
I have a follow up question on the RC change on pos_setpoint being read only and input_pos as direct replacement.
This change suggests that pos_setpoint as target of the PID “can” be different than input_pos. Is this the case in position control? If so under what conditions/scenarios would the target of the PID loop (pos_setpoint) be any different than input_pos in position control?
I’ve developed a tracking mode that is using position control. That tracking mode is a high level control loop that is external to ODrive and managed by an external controller communicating with the ODrive through UART/ASCII. One of the thing that this external loop is doing was measuring the error between the old “set_point” and “pos_estimate” which is the “real time” position readout. This proved to work pretty well. I’d like to make sure I understand how input_pos differs from the pos_setpoint. At first glance, for my specific purpose I feel like the error I am trying to assess should now be calculated off input_pos and pos_estimate. But I could be wrong and if it makes more sense to look at pos_setpoint I’ll do that.
Quick update: the ODrive is now flashed with the modified firmware (modified from the RC0.5) but I’ve yet to enable the absolute stuff yet as I need to make sure the GUI/control software is working correctly with the changes made to pos_estimate.
Cheers!
edit: I noticed the input mode were not explicitly declared to a value like errors, control modes, or axis states. I was able to change states through ASCII by just sending a number as parameter so I guess it’s not required.
Update!: I think I got the input_mode changes down. I have a weird problem as the input_mode doesn’t default to 1 but 0. Saving configuration and rebooting doesn’t help and every time I have to set it to 1 (passthrough) to enable position or velocity control to take the input pos/vel.
I did my first power on with the custom encoder installed.
Odrive is throwing a 0x08 error (unsupported encoder).
that also is very weird:
I have set a custom mode 0x103 (259 decimal).
in the encoder.cpp the only 3 pieces of code potentially throwing a 0x08 error are switches.
I have a case defined in all 3, so the only explanation is that somehow the switch is ignoring the additional case I defined.
it might be easier to understand what I mean if I copy pieces of my code:
inside encoder.hpp I have this:
 enum Mode_t {
MODE_INCREMENTAL,
MODE_HALL,
MODE_SINCOS,
MODE_SPI_ABS_CUI = 0x100,   //!< compatible with CUI AMT23xx
MODE_SPI_ABS_AMS = 0x101,   //!< compatible with AMS AS5047P, AS5048A/AS5048B (no daisy chain support)
MODE_SPI_ABS_AEAT = 0x102,  //!< not yet implemented
MODE_SPI_ABS_ZSI = 0x103,   //!< compatible with ZSI's custom hardware
then here are the 3 switches that throw a 0x08 error:
void Encoder::sample_now() {
switch (mode_) {
case MODE_INCREMENTAL: {
tim_cnt_sample_ = (int16_t)hw_config_.timer->Instance->CNT;
} break;
case MODE_HALL: {
// do nothing: samples already captured in general GPIO capture
} break;
case MODE_SINCOS: {
../..} break;
case MODE_SPI_ABS_AMS:
case MODE_SPI_ABS_CUI:
case MODE_SPI_ABS_ZSI:
case MODE_SPI_ABS_AEAT:
default: {
set_error(ERROR_UNSUPPORTED_ENCODER_MODE);
} break;
next one (not copying it) is in Encoder::abs_spi_cb()
and last in Encoder::update()
the weirdest of this problem is that the error will only get thrown if it can’t find a matching “case” for the defined encoder mode
Any idea?
edit: I recompiled and reflashed and it seems like the flashing process doesn’t erase the memory. Is this normal? Which would explain why the defined 0x103 is not being picked up by the switches
edit2: I did an erase config after flashing, that didn’t resolve the problem
edit3: wetmelon suggested on discord possibly missing a break; before the Switches “default” statement, which would push into default. I double checked and all 3 switches have break’s before the default. I couldn’t find any other piece of code that pushes a 0x8 encoder error anywhere. Which leaves me with original theory that my declaration for the custom mode isn’t being registered somehow, and so when I set the mode to 0x103 it systematically defaults out in the 3 switches causing that 0x8 encoder error. I want to believe that it is linked to input_mode issue, which is somewhat similar in that they both rely on enum declaration in encoder.hpp and controller.hpp respectively. I’ll try to flash directly from VScode using an STlink, perhaps there is an issue with dfuse
Update:
ok I am now sure the 2 issues (input_mode stuff) and my 0x08 error on the customer encoders are not linked!
Here’s what I found on the input_mode issue.
First of all, as a sanity check I decided to check I was getting the error in python command line since all I do is through Ascii. Just in case.
Sure enough, I could not replicated the issue with Python. After a clean flash, erase, going straight into python cli does return 1 on input_mode.
Next, going straight into ASCII command line without running any preliminary (scripting/config) commands, it also returns 1 on input_mode.
So I started to slowly un-commenting stuff to see which command create a problem:
I found that setting control_mode a value (3 in my case, which is also the default, other values game me the same results) systematically also sets input_mode to 0.
I went back into python, and repeated the same command: odrv0.axis0.controller.config.control_mode = 3 then calling odrv0.axis0.controller.config.input_mode, which returns 1 as it should.
Repeated the process in ASCII CLI and input_mode always returns 0 after setting control_mode to any value.
edit 2:
I did a test with putty, not super practical UI but I was able to verify the issue - so at least I know for sure my GUI is not the cause
edit 3:
I remembered one of the RC change is the fact ASCII ‘w’ commands now executes hooks. Perhaps the fact control_mode affects input_mode when using ASCII has to do with a hook that shouldn’t take place. So I tracked the ASCII commands as far as I could and found this:
I can’t really tell if there is a hook defined for axis0.controller.config.control_mode but I don’t think so. Or maybe I just can’t recognize what the hook is supposed to look like. If there was one I’d think it would show here:
Sorry for the all the updates, logging stuff in case it helps someone adding another encoder down the road.
  1. update on the input_mode issue
Edit: this bug was reproduced and already fixed thanks guys: https://github.com/madcowswe/ODrive/issues/432
it’s only happening with ascii over usbser driver (haven’t checked the onboard uart yet, might do that tomorrow). I repeated the issue with putty and my own gui. every time control_mode is written to, input_mode is set to 0.
I looked for a write hook, even commented out what I think was the hook and it gave me the same behavior. So if a hook is the cause commenting out lines 829-831 in fiber’s protocol.hpp did not fix it.
  1. custom encoder code
I tried a bunch of different things, not being able to send ascii commands while debugging isn’t helping. I added additional error setting for the encoder to identify which of the 3 switches was causing the trouble. turns out, the first and third are outputting the error. And I suspect the third would also but I never get there.
I changed the order in the case statements, no change. I tried using a hard coded 259 (instead of the enum label). Same result.
At this point I think that the axis0.encoder.config.mode is never applied to the mode_ variable inside encoder.cpp. Which is weird cause it is! every reboot when Encoder::setup() is executed:
  mode_ = config_.mode;
Is there another place that the enum labels would be used for some entry verification of some sort?
setting encoder.config.mode to 257 (AMS) makes the errorr 0x8 go away.
Edit: I made a tiny of progress. The 0x08 (unsupported encoder) error is getting triggered somehow when these lines (365-370) are executed.
I am able to completely remove the error by removing this test and just executing the line that’s part of the RC (that line is not sufficient as I need to use a larger buffer).
HAL_SPI_TransmitReceive_DMA(hw_config_.spi, (uint8_t*)abs_spi_dma_tx_, (uint8_t*)abs_spi_dma_rx_, 1);
keeping my code but changing the size from 5 to 1 also removes the error 0x08.
I do have the datasize set to 8 bit instead of 16, and I am using a different buffer variable array:
what’s puzzling me is this 0x08 error which is triggered in a different part of the code and the only explanation for it is that mode_ is being assigned a value that makes the case statement false and get me through the default case which triggers that error.
Edit: Still don’t have an explanation as to what is changing the value of mode_
But having isolated the error to be triggered when executing the hal spi transmit received DMA I played with the size of the data to send, brought it down to 1 (same as for the AMS/CUI stuff) and it wen through not rejecting a 0x08 but instead the more likely 0x80 corresponding to a fail SPI comm which is what I want at this point since I expect some tweaking of the SPI parameters (baudrate, edge/phase, etc). I increased the value up to 4 without throwing that 0x08, and it’s only when the size of 5 is used that it starts throwing the 0x08. Chasing my tail a little…
…but this brought me to dig in that direction and found that I did majorly overlooked the HAL SPI tx/rx complete callback that’s located inside low_level.cpp
I added another test on mode_ so that the tests would take place off the correct buffer (using my larger one).
Hopeful, I compiled and sadly it’s still throwing the same error. I might pull the logic analyzer to see what’s going on those SPI pins. I am expecting that with that 0x08 I’ll probably won’t see anything but who knows.
Is it possible that I am transmitting/receiving too much data and that somehow the loop is already trying to transmit/receive before the previous message was received. Trying to make sense of why would the size of the TX message would result in different error output.
Big progress this morning, kind of.
The issue from the beginning was the size of the buffer on this line:
HAL_SPI_TransmitReceive_DMA(hw_config_.spi, (uint8_t*)abs_spi_zsi_dma_tx_, (uint8_t*)abs_spi_zsi_dma_rx_, 5);
I need to send 5x 8bit bytes, the message defined in the buffer declaration is: A6,0,0,0,0.
The 4 bytes at 0x00 are meant to keep the communication open while the encoder is transmitting, but really the 0’s are ignored.
That being said, something is preventing me from setting that buffer to 5. One of tests I did yesterday was to basically comment all my code, and gradually observing what error code was being thrown out. That’s how I realized the issue was coming from that line. From there I decided to change the buffer size to 1. The 0x08 went away immediately. But at this point I was finally seeing something happening on the SPI bus.
I gradually increased the buffer size and I still see stuff happening on the SPI bus with the buffer size to 4.
At this point I decided to focus on cleaning up my settings to see if I could get the encoder to talk/respond.
here’s where I’m at:
  1. CS on channel 1, CLK on channel 2, MOSI on channel 3, MISO on channel 4.
  2. B1 is the decoding of MOSI
  3. B2 is the decoding of MISO
    Note: my prescaler is 8 so the clock speed is 4 times faster than with the AMS/CUI (I did that thinking perhaps the reason why I could not set the buffer to 5 was that the bigger buffer was taking too much time to get processed)
  4. MOSI shows the first 2 bytes are proper (0xA6, 0x00)
  5. However starting on the 3rd byte, MOSI is incrrorect. A6 should not be there (even though it is ignored since the encoder is in the middle of pushing position data)
  6. On MISO everything is as expected (first byte A6 is normal and means the encoder has received the position read command, and the following 3 bytes are position data; because I am missing the fifth byte the CRC data is missing)
  7. The real good news are:
  • that physically moving the rotor does change the numbers on MISO
  • running pos_estimate on a loop does show values and the position does plot properly on the graph
  1. One weird thing that is happening is when turning the rotor (moving the encoder position) there is a zone (very repeatable) where MOSI shifts down almost as if its polarity or phase had changed. MISO on the other hand is not affected whatsoever and the ODrive is able to read the position i.e. looking at the pos_estimate on a graph shows normal behavior. Really weird.
comments/questions:
  • Although it’s great I just can’t make any sense of why I can actually read the data.
    Because, in my code, unless CRC has been verified as valid, the reconstructed position data from the 3 middle bytes are never being applied to the ‘pos’ variable. But perhaps because the fifth byte is not read, it must be 0, so the CRC verification code is happening, I am just not sure how the CRC is actually found valid. I won’t worry too much about that, as I know the CRC decode is working since it’s been tested extensively on the Due prior to starting these tests on the ODrive. For now the real questions are:
  • why am I not able to set the buffer size to 5?
  • why is MOSI not reading 0xA6 followed by strictly 0’s (the Tx buffer must be overwritten by the Rx buffer somewhere - I should be able to find where if it’s simple rx/tx variable error?
  • why is the setting of CS back to high taking so much time after data has been captured by the callback? Timeout?
here’s how my Spi init is defined (all the other settings not listed are the same as the default for AMS/CUI)
if (mode_ == MODE_SPI_ABS_ZSI) {
     spi->Init.Direction = SPI_DIRECTION_2LINES;
     spi->Init.DataSize = SPI_DATASIZE_8BIT;
     spi->Init.CLKPolarity = SPI_POLARITY_LOW;
     spi->Init.CLKPhase = SPI_PHASE_1EDGE;
     spi->Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_8
     spi->Init.FirstBit = SPI_FIRSTBIT_MSB;
edit: all of the above fixed by https://github.com/madcowswe/ODrive/pull/433 :smiley:
Update: still digging but I think it’s possible there is an issue with pos_estimate.
I initially thought I was having noise issues because the “jumps” in pos_estimate would be systematic while trying to calibrate (on the forward scan, it errors out before the backward scan), and a lot more difficult to trigger this problem when moving the rotor by hand.
I since then added pos_cpr to my plots and the pos_cpr is basically as expected - not perfect, some slight oscillations which could be cogging (test motor, high resistance but very coggy as 12N14P…).
I also thought about overflowing but after repeating the test several times, how high (or low) it will go seems random. I also looked through the offset_calibration function and at first glance it doesn’t look like any of the variable used for the calculations/estimations could be overflowing, but I’ll need to take a closer look.
Hey Zytra,
That’s a nice looking GUI you have… Have you published it anywhere? :slight_smile:
Hey
Not yet but I am considering at least providing the executable.
It was meant to be more of the UI for the project I am working on but it slowly migrated into more of a development platform for this project. So it is slowly being populated with pretty much all ODrives parameters. It has a bunch of ODrive-external features most of which are either done or close to being done, like autotuning, a position tracking mode.
What language is it written in?
C#, winform, .net framework.
boooo :stuck_out_tongue_closed_eyes:
how did you get it to interface with the Python library?
I didn’t.
Ascii hasn’t been limiting so far.
Huh, fair enough!
Btw the one thing that really makes me dislike .NET apps (apart from Microsoft) is that they don’t work in WINE… :stuck_out_tongue:
As for your encoder issue… Have you tried looking at shadow_count? or count_in_cpr? (if these are available via the ASCII interface) - these represent the position as read directly out of the encoder (shadow_count is unwrapped whereas cpr wraps around), whereas pos_estimate comes from some kind of state observer or Kalman filter afaik.
I looked at both and both are acting up like pos_estimate.
Pos_cpr seems not to show have sign of problem tho
Update:
I added chart series for pos_cpr, shadow_count and count_in_cpr.
Also fixed an error in my CRC verification code which was ported from the Due - that fixed the 0x80 error when the rotor was standing still. I had disabled the CRC (before I realized the error in the code) which allowed me to at least get past the error.
Now why all these jumps on pos_estimate? my theory right now is noise. And now that the CRC verification is active, I am pretty sure that’s what’s happening.
Yesterday without the CRC verif corrupted data all positions were accepted, causing the estimators to see large increases in speed, hence throwing the position estimation way off.
Today, with correct CRC verification I am still able to see these weird jumps when moving the rotor by hand, although most of them were taking place after many turns with pos_estimates extremely large (hundreds of millions counts). If the CRC was bulletproof (no CRC is, and a 6bit CRC of 24bit CRC certainly isn’t) one explanation would be overflow. I can’t rule that out yet, but one thing is almost certain is that my pos_cpr and count_in_cpr aren’t showing any sign of jump. Jumps are only seen on shadow_count and pos_estimate. I have separated the graphs for the 2 CPR type variables for better scaling. I forgot to screenshot when jumps were taking place (shadow_count and pps_estimate).
The other nice piece of info is that with the CRC verification working, I am NOT able to get as far in the OFFSET_CALIB, with a 0x80 error after the very first part of the calib, before the 2 scans. This error suggests a failed SPI communication, and my theory is that the short period of time where the motor is powered on is causing sufficient noise on the SPI bus to trip that 0x80 error.
Yesterday with the CRC disabled, the crazy jumping during the calibration does correlate that. I was fully ignoring 0x80 so I would actually run the first scan during which crazy jumping would be explained by significant noise on the SPI bus causing wrong positions to be read.
Beside line resistors and a pull down on MISO I have literally nothing else to shield the SPI bus so I’ll do that next and report back.
When you talk about CRCs, do you mean the ASCII interface over USB, or are you talking about the SPI comms with the encoder? I don’t think the AS5047p provides a CRC?
Which actual chip are you using?
Can you post your plots for shadow_count and count_in_cpr?
Does the “crazy jumping” tend to happen in the same physical position? It may be that you have your bit mapping wrong somewhere
However, if count_in_cpr is correct then it could be an issue with the ODrive firmware. Maybe nobody has tried a 22bit encoder until now? Can you truncate it to 16bit and see if it works then?
By CRC I mean, actual custom code to verify the CRC that’s transmitted at the end of the 5 byte message.
I don’t have a screenshot right now but I’ll take one later. You can also take a look at the one I posted with comments yesterday you’ll see pos_cpr and pos_estimate. As far as I could tell pos_cpr did not jump.
For sure since I added shadow_count and count_in_cpr to the graphs, I can tell that shadow_count is following pos_estimate closely.
count_in_cpr is the raw data and I have not seen it jump anytime so I am not ruling out a bug (overflow or something). But I am pretty sure that aside from that I do have a noise problem which is constituent with the last 2 days of observations and it only trips the 0x80 error when the motor is spinning.
update: everything seems to be up and running.
the issue with calibration was electrical/noise (feedback from using separate PSU’s for encoder and ODrive). Powering the electronics with the ODrive’s 3.3 fixed the noise issue and calibrated on the first try.
I’ll be testing pre-calibration next
cheers
