Thank you guys in advance.
When Odrive is in speed slope mode, once the motor starts, it will move a little, then it will be stuck, and the current will run to 17A, which will increase with time. I can confirm that hardware like encoder is ok (because motor detection and encoder offset calibration can pass). Do you have the same problem as me? Do you have a solution?
