Hello, what are the limitations of analog control of Odrive Pro?
- In velocity control, could i reliably control the speed via analog input between 0 and 7000 rpm?
- In position control, is it only suited to control the motor in a small area, a couple of turns?
You can arbitrarily set the position and velocity bounds, but realistically there will always be some analog noise, so I wouldn’t recommend setting the position range too large. You can assume it’ll be about a 10bit usable range (0-1024).
Why are you considering analog input instead of USB/CAN/UART/etc?
Just curious about it really, and how it adds up for trajectory control with analog vel input (with feedback to a external controller) vs feeding a trajectory with filtered position control via canbus or just feeding step/dir directly?
Im guessing 0-3.3V analog signal over some distance (2-3 m) may introduce some noise.
You absolutely 100% want anything but analog
Step/dir is fine, streaming over CAN is great. Above 250Hz-1kHz command rates (depending on the application), it’s fast enough to not matter.
Yeah, thats what I suspected
Thank you!
