Is there a way to run the anticogging calibration in the web GUI I have an ODrive S1 that I am putting on a CNC laser but am having difficulty getting anticogging to work. If I enable anticogging, I get a phase error
Hi! You can use the inspector tab in the web GUI – it provides the same functionality as ODrivetool.
What error are you getting?
It is erroring out saying missing estimate. how do you input the command to run the anticogging calibration I would assume it would be in the inspector tab under the variable list?
Did you follow the instructions to set up a position reference frame? This is required for anticogging: Anticogging — ODrive Documentation 0.6.10 documentation
Seems like you’re on the right track ![]()
