I’m having problem running AS5048A encoder on v.3.6 ODrive 56V with rc-v0.5.1 firmware. I connected everything as it says here. SCK, MISO and GND to the same named pins on ODrive. MOSI, 3.3V and 5V on encoder connected together to 3.3V on ODrive. I only have M0 motor. I also applied fix as suggested here. I still get error immediately as ODrive is connected. As soon as it connects I run command dump_errors(odrive0) and get the following:
axis: Error(s):
ERROR_ENCODER_FAILED
motor: no error
encoder: Error(s):
ERROR_ILLEGAL_HALL_STATE
axis1
axis: no error
motor: no error
when I run command : odrv0.axis0.encoder, i get the following:
error = 0x0010 (int)
is_ready = False (bool)
index_found = False (bool)
shadow_count = 0 (int)
count_in_cpr = 0 (int)
interpolation = 0.0 (float)
phase = 0.0 (float)
pos_estimate = 0.0 (float)
pos_estimate_counts = 0.0 (float)
pos_cpr = 0.0 (float)
pos_cpr_counts = 0.0 (float)
pos_circular = 0.0 (float)
hall_state = 7 (int)
vel_estimate = 0.0 (float)
vel_estimate_counts = 0.0 (float)
calib_scan_response = 0.0 (float)
pos_abs = 0 (int)
spi_error_rate = 0.0 (float)
config:
mode = 1 (int)
use_index = False (bool)
abs_spi_cs_gpio_pin = 4 (int)
cpr = 16384 (int)
offset = 0 (int)
pre_calibrated = False (bool)
offset_float = 0.0 (float)
bandwidth = 1000.0 (float)
sincos_gpio_pin_sin = 3 (int)
sincos_gpio_pin_cos = 4 (int)
set_linear_count(count: int)
I also cannot run offset calibration.
This new version doesn’t have
