Here is the revised version of that code, VSM motors (6354 190kv) run trapezoidal trajectory position control and belt motors (63100 190kv) run ramped velocity control for reference, both use AMT102-v 8192 CPR encoders with index, the VSM code works flawlessly but I haven’t been able to test the belt code since the encoders are not mounted yet (switching from halls to encoders)
This is a long one
VSTA002.py written by Zachary The’ on October 11th, 2022 for HORC Lab VST 2.0
Contact at +1 (302) 753-3570 or thezach@udel.edu
For odrive info visit Getting Started — ODrive Documentation 0.5.5 documentation
Using ODrive v3.6-56V
To install/update odrivetool run … in command window
pip install --upgrade odrive
Running ODrive control utility v0.6.3
To install missing modules run … or … in command window
conda install -c conda-forge
pip install
Ro resolve USB issues visit https://zadig.akeo.ie/
Run application, Options > List All Devices, ODrive 3.6 Native Interface (Interface 2), libusb-win32 (v.1.2.6.0), Install Driver
To update odrive firmware run … in command window, use Zadig utility to set STM32 BOOTLOADER to libusb-win32
odrivetool dfu
Running v0.5.5.0
To open plotter run …
odrivetool
import matplotlib
matplotlib.use(‘TkAgg’)
cancellation_token = start_liveplotter(lambda: [])
odrv0 → ODrive 316D335C3030 (patient left)
odrv1 → ODrive 3359365B3539 (patient right)
axis0 → VSM
axis1 → Belt
import os
import sys
import time
from cmath import pi
from logging import exception
import odrive
from odrive.utils import *
def countdown(t, note):
print()
for i in range(t):
if (t - i) > 1:
print(f"\033[A{note}: Please wait {t - i:.0f} seconds ")
else:
print(f"\033[A{note}: Please wait 1 second ")
time.sleep(1)
os.system('cls')
def update_odrives(odrv0, odrv0_ID, odrv1, odrv1_ID, mode):
# Mode 0 --> save
# Mode 1 --> erase
# Mode 2 --> reboot
t = 3
odrv0.axis0.requested_state = 1
odrv0.axis1.requested_state = 1
odrv1.axis0.requested_state = 1
odrv1.axis1.requested_state = 1
try:
if mode == 0:
odrv0.save_configuration()
elif mode == 1:
odrv0.erase_configuration()
else:
odrv0.reboot()
except:
pass
try:
if mode == 0:
odrv1.save_configuration()
elif mode == 1:
odrv1.erase_configuration()
else:
odrv1.reboot()
except:
pass
if mode == 0:
countdown(t, f"Saving ODrives")
elif mode == 1:
countdown(t, f"Erasing ODrives")
else:
countdown(t, f"Rebooting ODrives")
odrv0 = odrive.find_any(serial_number=odrv0_ID)
odrv1 = odrive.find_any(serial_number=odrv1_ID)
check_errors(odrv0, odrv1)
return odrv0, odrv1
def check_errors(odrv0, odrv1):
if odrv0.error or odrv1.error:
os.system('cls')
print(dump_errors(odrv0))
print()
input(dump_errors(odrv1))
sys.exit()
def autocal_VSM(odrv0, odrv0_ID, odrv1, odrv1_ID):
# Write configurations
odrv0.axis0.config.startup_closed_loop_control = True # {False}
odrv0.axis0.config.startup_encoder_index_search = True # {False}
odrv0.axis0.controller.config.control_mode = 3 # position control {3}
odrv0.axis0.controller.config.input_mode = 5 # trap traj {1}
odrv0.axis0.controller.config.pos_gain = 15 # {20}
odrv0.axis0.controller.config.vel_gain = 0.1667 # {0.1667}
odrv0.axis0.controller.config.vel_integrator_gain = 10.3333 # {0.3333}
odrv0.axis0.controller.config.vel_limit = 66 # {2}
odrv0.axis0.encoder.config.use_index = True # {False}
odrv0.axis0.motor.config.calibration_current = 20 # {10}
odrv0.axis0.motor.config.current_lim = 65 # {10}
odrv0.axis0.motor.config.current_lim_margin = 52 # {8}
odrv0.axis0.motor.config.requested_current_range = 130 # {60}
odrv0.axis0.motor.config.torque_constant = 8.27/190 # {0.04}
odrv0.axis0.trap_traj.config.accel_limit = 100 # {0.5}
odrv0.axis0.trap_traj.config.decel_limit = 100 # {0.5}
odrv0.axis0.trap_traj.config.vel_limit = 60 # {2}
odrv0.config.dc_max_positive_current = 20 # {inf}
odrv0.config.enable_brake_resistor = True # {False}
odrv1.axis0.config.startup_closed_loop_control = True # {False}
odrv1.axis0.config.startup_encoder_index_search = True # {False}
odrv1.axis0.controller.config.control_mode = 3 # position control {3}
odrv1.axis0.controller.config.input_mode = 5 # trap traj {1}
odrv1.axis0.controller.config.pos_gain = 15 # {20}
odrv1.axis0.controller.config.vel_gain = 0.1667 # {0.1667}
odrv1.axis0.controller.config.vel_integrator_gain = 0.3333 # {0.3333}
odrv1.axis0.controller.config.vel_limit = 66 # {2}
odrv1.axis0.encoder.config.use_index = True # {False}
odrv1.axis0.motor.config.calibration_current = 20 # {10}
odrv1.axis0.motor.config.current_lim = 65 # {10}
odrv1.axis0.motor.config.current_lim_margin = 52 # {8}
odrv1.axis0.motor.config.requested_current_range = 130 # {60}
odrv1.axis0.motor.config.torque_constant = 8.27/190 # {0.04}
odrv1.axis0.trap_traj.config.accel_limit = 100 # {0.5}
odrv1.axis0.trap_traj.config.decel_limit = 100 # {0.5}
odrv1.axis0.trap_traj.config.vel_limit = 60 # {2}
odrv1.config.dc_max_positive_current = 20 # {inf}
odrv1.config.enable_brake_resistor = True # {False}
# Save configurations
odrv0, odrv1 = update_odrives(odrv0, odrv0_ID, odrv1, odrv1_ID, 0)
# Calibrate motors
str_in = input("Press ENTER to start VSM motor detection or X to skip\n")
os.system('cls')
if str_in in ['x', 'X']:
pass
else:
odrv0, odrv1 = calib_VSM(odrv0, odrv0_ID, odrv1, odrv1_ID)
# Anticog motors
str_in = input("Press ENTER to start VSM anticogging or X to skip\n")
os.system('cls')
pass
else:
odrv0, odrv1 = anticog_VSM(odrv0, odrv0_ID, odrv1, odrv1_ID)
# Home motors
str_in = input("Press ENTER to start VSM homing or X to skip\n")
os.system('cls')
pass
else:
odrv0, odrv1 = home_VSM(odrv0, odrv0_ID, odrv1, odrv1_ID)
return odrv0, odrv1
def calib_VSM(odrv0, odrv0_ID, odrv1, odrv1_ID):
odrv0.axis0.encoder.config.pre_calibrated = False # {False}
odrv0.axis0.motor.config.pre_calibrated = False # {False}
odrv1.axis0.encoder.config.pre_calibrated = False # {False}
odrv1.axis0.motor.config.pre_calibrated = False # {False}
# Calibrate motors
odrv0.axis0.requested_state = 3
odrv1.axis0.requested_state = 3
countdown(18, f"Calibrating VSM motors")
os.system('cls')
# Check errors
odrv0.axis0.encoder.config.pre_calibrated = True # {False}
odrv0.axis0.motor.config.pre_calibrated = True # {False}
odrv1.axis0.encoder.config.pre_calibrated = True # {False}
odrv1.axis0.motor.config.pre_calibrated = True # {False}
return odrv0, odrv1
def anticog_VSM(odrv0, odrv0_ID, odrv1, odrv1_ID):
# Index search
if (not odrv0.axis0.encoder.index_found) or (not odrv1.axis0.encoder.index_found):
odrv0.axis0.requested_state = 6
odrv1.axis0.requested_state = 6
time.sleep(1)
# Check errors
# Write parameters
odrv0.axis0.controller.config.anticogging.pre_calibrated = False # {False}
odrv0.axis0.controller.config.control_mode = 2 # velocity control {3}
odrv0.axis0.controller.config.input_mode = 1 # passthrough {1}
odrv0.axis0.controller.config.pos_gain = 10 * 20 # {20}
odrv0.axis0.controller.config.vel_integrator_gain = 10 * 0.3333 # {0.3333}
odrv0.axis0.controller.config.vel_limit = 2 # {2}
odrv1.axis0.controller.config.anticogging.pre_calibrated = False # {False}
odrv1.axis0.controller.config.control_mode = 2 # velocity control {3}
odrv1.axis0.controller.config.input_mode = 1 # passthrough {1}
odrv1.axis0.controller.config.pos_gain = 10 * 20 # {20}
odrv1.axis0.controller.config.vel_integrator_gain = 10 * 0.3333 # {0.3333}
odrv1.axis0.controller.config.vel_limit = 2 # {2}
# Anticog motors
odrv0.axis0.requested_state = 8
odrv0.axis0.controller.start_anticogging_calibration()
odrv1.axis0.requested_state = 8
odrv1.axis0.controller.start_anticogging_calibration()
anticog0 = True
anticog1 = True
i0 = odrv0.axis0.encoder.pos_estimate_counts
i1 = odrv1.axis0.encoder.pos_estimate_counts
t = time.time()
time.sleep(1)
print()
while anticog0 or anticog1:
if anticog0 and odrv0.axis0.controller.config.anticogging.calib_anticogging:
com0 = abs(odrv0.axis0.encoder.pos_estimate_counts - i0) / 8192
elif anticog0:
# odrv0.axis0.encoder.set_linear_count(0)
anticog0 = False
com0 = 1
if anticog1 and odrv1.axis0.controller.config.anticogging.calib_anticogging:
com1 = abs(odrv1.axis0.encoder.pos_estimate_counts - i1) / 8192
elif anticog1:
# odrv1.axis0.encoder.set_linear_count(0)
anticog1 = False
com1 = 1
dt = time.time() - t
print(
f"\033[AAnticogging VSM motors: Please wait approximatly {(dt / min(com0, com1) - dt) :.0f} seconds ({dt:.0f} seconds elapsed, VSM 0 {100 * com0:.0f}% complete, VSM 1 {100 * com1:.0f}% complete) ")
# Check errors
odrv0.axis0.controller.config.anticogging.pre_calibrated = True # {False}
odrv0.axis0.controller.config.input_mode = 5 # trapazoidal {1}
odrv0.axis0.controller.config.vel_integrator_gain = 0.3333 # {0.3333}
odrv1.axis0.controller.config.anticogging.pre_calibrated = True # {False}
odrv1.axis0.controller.config.input_mode = 5 # trapazoidal {1}
return odrv0, odrv1
def home_VSM(odrv0, odrv0_ID, odrv1, odrv1_ID):
print("Homing VSM motors: Please wait up to 30 seconds")
# Index search
time.sleep(1)
# Check errors
# Update parameters
odrv0.axis0.controller.config.input_mode = 1 # passthrough {3}
odrv1.axis0.controller.config.input_mode = 1 # passthrough {3}
# Start homing search
odrv0.axis0.requested_state = 8 # closed loop control
odrv0.axis0.controller.input_vel = -1
odrv1.axis0.requested_state = 8 # closed loop control
odrv1.axis0.controller.input_vel = -1
home0 = True
home1 = True
while home0 or home1:
if home0 and abs(odrv0.axis0.motor.current_control.Iq_measured) > 20:
odrv0.axis0.controller.input_vel = 0
odrv0.axis0.encoder.set_linear_count(-1932)
home0 = False
if home1 and abs(odrv1.axis0.motor.current_control.Iq_measured) > 20:
odrv1.axis0.controller.input_vel = 0
odrv1.axis0.encoder.set_linear_count(-2151)
home1 = False
# Check errors
# Update parameters
# Move infinite stiffness
odrv0.axis0.controller.input_pos = 0
odrv1.axis0.controller.input_pos = 0
time.sleep(1)
os.system('cls')
# Check errors
return odrv0, odrv1
def autocal_belt(odrv0, odrv0_ID, odrv1, odrv1_ID):
odrv0.axis1.config.startup_closed_loop_control = True # {False}
odrv0.axis1.config.startup_encoder_index_search = True # {False}
odrv0.axis1.controller.config.control_mode = 2 # velocity control {3}
odrv0.axis1.controller.config.input_mode = 2 # vel ramp {1}
odrv0.axis1.controller.config.pos_gain = 15 # {20}
odrv0.axis1.controller.config.vel_gain = 0.1667 # {0.1667}
odrv0.axis1.controller.config.vel_integrator_gain = 10.3333 # {0.3333}
odrv0.axis1.controller.config.vel_limit = 114 # {2}
odrv0.axis1.controller.config.vel_ramp_rate = 8 # {1}
odrv0.axis1.encoder.config.use_index = True # {False}
odrv0.axis1.motor.config.calibration_current = 20 # {10}
odrv0.axis1.motor.config.current_lim = 100 # {10}
odrv0.axis1.motor.config.current_lim_margin = 80 # {8}
odrv0.axis1.motor.config.requested_current_range = 200 # {60}
odrv0.axis1.motor.config.torque_constant = 8.27/190 # {0.04}
odrv1.axis1.config.startup_closed_loop_control = True # {False}
odrv1.axis1.config.startup_encoder_index_search = True # {False}
odrv1.axis1.controller.config.control_mode = 2 # velocity control {3}
odrv1.axis1.controller.config.input_mode = 2 # vel ramp {1}
odrv1.axis1.controller.config.pos_gain = 15 # {20}
odrv1.axis1.controller.config.vel_gain = 0.1667 # {0.1667}
odrv1.axis1.controller.config.vel_integrator_gain = 0.3333 # {0.3333}
odrv1.axis1.controller.config.vel_limit = 114 # {2}
odrv1.axis1.controller.config.vel_ramp_rate = 8 # {1}
odrv1.axis1.encoder.config.use_index = True # {False}
odrv1.axis1.motor.config.calibration_current = 20 # {10}
odrv1.axis1.motor.config.current_lim = 100 # {10}
odrv1.axis1.motor.config.current_lim_margin = 80 # {8}
odrv1.axis1.motor.config.requested_current_range = 200 # {60}
odrv1.axis1.motor.config.torque_constant = 8.27/190 # {0.04}
# Calibrate motors
str_in = input("Press ENTER to start belt motor detection or X to skip\n")
os.system('cls')
pass
else:
odrv0, odrv1 = calib_belt(odrv0, odrv0_ID, odrv1, odrv1_ID)
# Anticog motors
str_in = input("Press ENTER to start belt anticogging or X to skip\n")
os.system('cls')
pass
else:
odrv0, odrv1 = anticog_belt(odrv0, odrv0_ID, odrv1, odrv1_ID)
return odrv0, odrv1
def calib_belt(odrv0, odrv0_ID, odrv1, odrv1_ID):
odrv0.axis1.encoder.config.pre_calibrated = False # {False}
odrv0.axis1.motor.config.pre_calibrated = False # {False}
odrv1.axis1.encoder.config.pre_calibrated = False # {False}
odrv1.axis1.motor.config.pre_calibrated = False # {False}
# Calibrate motors
odrv0.axis1.requested_state = 3
odrv1.axis1.requested_state = 3
countdown(18, f"Calibrating belt motors")
os.system('cls')
# Check errors
odrv0.axis1.encoder.config.pre_calibrated = True # {False}
odrv0.axis1.motor.config.pre_calibrated = True # {False}
odrv1.axis1.encoder.config.pre_calibrated = True # {False}
odrv1.axis1.motor.config.pre_calibrated = True # {False}
return odrv0, odrv1
def anticog_belt(odrv0, odrv0_ID, odrv1, odrv1_ID):
# Index search
if (not odrv0.axis1.encoder.index_found) or (not odrv1.axis1.encoder.index_found):
odrv0.axis1.requested_state = 6
odrv1.axis1.requested_state = 6
time.sleep(1)
# Check errors
# Write parameters
odrv0.axis1.controller.config.anticogging.pre_calibrated = False # {False}
odrv0.axis1.controller.config.input_mode = 1 # passthrough {1}
odrv0.axis1.controller.config.pos_gain = 10 * 20 # {20}
odrv0.axis1.controller.config.vel_integrator_gain = 10 * 0.3333 # {0.3333}
odrv0.axis1.controller.config.vel_limit = 2 # {2}
odrv1.axis1.controller.config.anticogging.pre_calibrated = False # {False}
odrv1.axis1.controller.config.input_mode = 1 # passthrough {1}
odrv1.axis1.controller.config.pos_gain = 10 * 20 # {20}
odrv1.axis1.controller.config.vel_integrator_gain = 10 * 0.3333 # {0.3333}
odrv1.axis1.controller.config.vel_limit = 2 # {2}
# Anticog motors
odrv0.axis1.requested_state = 8
odrv0.axis1.controller.start_anticogging_calibration()
odrv1.axis1.requested_state = 8
odrv1.axis1.controller.start_anticogging_calibration()
anticog0 = True
anticog1 = True
i0 = odrv0.axis1.encoder.pos_estimate_counts
i1 = odrv1.axis1.encoder.pos_estimate_counts
t = time.time()
time.sleep(1)
print()
if anticog0 and odrv0.axis1.controller.config.anticogging.calib_anticogging:
com0 = abs(odrv0.axis1.encoder.pos_estimate_counts - i0) / 8192
elif anticog0:
anticog0 = False
com0 = 1
if anticog1 and odrv1.axis1.controller.config.anticogging.calib_anticogging:
com1 = abs(odrv1.axis1.encoder.pos_estimate_counts - i1) / 8192
elif anticog1:
anticog1 = False
com1 = 1
print(
f"\033[AAnticogging belt motors: Please wait approximatly {(dt / min(com0, com1) - dt) :.0f} seconds ({dt:.0f} seconds elapsed, belt 0 {100 * com0:.0f}% complete, belt 1 {100 * com1:.0f}% complete) ")
# Check errors
odrv0.axis1.controller.config.anticogging.pre_calibrated = True # {False}
odrv0.axis1.controller.config.vel_integrator_gain = 0.3333 # {0.3333}
odrv1.axis1.controller.config.anticogging.pre_calibrated = True # {False}
return odrv0, odrv1
def main():
os.system('cls')
print("Loading Variable Stiffness Treadmill Autocalibration v002")
odrv0_ID = '316D335C3030'
odrv1_ID = '3359365B3539'
os.system('cls')
# Clear, erase, or quit
str_in = input(
"Press ENTER to clear errors, E to erase configurations, or X to quit\n")
os.system('cls')
sys.exit()
elif str_in in ['e', 'E']:
odrv0, odrv1 = update_odrives(odrv0, odrv0_ID, odrv1, odrv1_ID, 1)
else:
odrv0.clear_errors()
odrv1.clear_errors()
# Autocal VSM motors
str_in = input(
"Press ENTER to start VSM autocalibration or X to skip\nRemove platform and center carriage prior to calibration\n")
os.system('cls')
pass
else:
odrv0, odrv1 = autocal_VSM(odrv0, odrv0_ID, odrv1, odrv1_ID)
# Autocal belt motors
str_in = input(
"Press ENTER to start belt autocalibration or X to skip\nRemove roller gear prior to calibration\n")
os.system('cls')
pass
else:
odrv0, odrv1 = autocal_belt(odrv0, odrv0_ID, odrv1, odrv1_ID)
main()
