Hello!
I am trying to run 325KV motor in Sensorless mode. However, I keep getting this error
system: not found
axis: Error(s):
AxisError.INVALID_STATE
motor: no error
DRV fault: not found
axis1
axis: no error
motor: no error
None
This is my code:
import odrive
from odrive.enums import *
import time
odrv0 = odrive.find_any()
print(str(odrv0.vbus_voltage))
print("Erasing pre-exsisting configuration...")
try:
odrv0.erase_configuration()
except Exception:
pass
odrv0.config.brake_resistance = 2.0 #(based on the resistor used for the Odrive)
# odrv0.config.dc_max_positive_current = 20.0 #(whatever is the max current that the power supply or the battery can give)
odrv0.config.dc_max_negative_current = -3.0 #(whatever is the max current that the power supply or the battery can absorb)
odrv0.config.max_regen_current = 1.5 #(usually 0)
# odrv0.config.dc_bus_undervoltage_trip_level = 5
# odrv0.config.dc_bus_overvoltage_trip_level = 20
odrv0.axis0.motor.config.requested_current_range = 20
odrv0.axis0.motor.config.current_lim = 60
odrv0.axis0.motor.config.calibration_current = 15
odrv0.axis0.controller.config.vel_limit = 100
odrv0.axis0.controller.config.vel_integrator_gain = 0.2
odrv0.axis0.sensorless_estimator.config.pm_flux_linkage = 5.51328895422 / (7*325)
try:
odrv0.save_configuration()
except:
pass
time.sleep(15)
print(str(odrive.utils.dump_errors(odrv0)))
print('Motor Calibration Sequence for motor 1')
try:
except:
pass
try:
odrv0.reboot()
except:
pass
odrv0.axis0.requested_state = AXIS_STATE_SENSORLESS_CONTROL
odrv0.axis0.config.startup_sensorless_control = True
print('Saving config before running')
try:
except:
pass
try:
odrv0.reboot()
except:
pass
time.sleep(5)
odrv0.axis0.controller.input_vel = 5
The strange thing is that despite it makes a sound that we usually get before calibration, motor does not turn at all.
Thank you!
