Heya guys!  I’ve got a ODrive 3.6 w/ a 48V 21A power supply and the stock 50W 2 Ohm brake resistor, I’m using it with 100W (velocity control) and 65W (position control) BLDC motors
Do I size wires for 1A (DC bus current) or 165A (max phase current)?
Also is it worth getting thermal pads or thermal paste?  It’s on a 0.125" 7075 Al plate
              Size the brake resistor wires for average DC bus regen current, which is going to be some super low duty cycle pulsed load unless you’re hammering stops & starts really hard.  200W at 48V is only ~4A peak, so you can use those 1A  wires if you have 25% duty cycle.
              Sweet thank you!  Already used 16awg so good for 22A easily but knowing it’ll never get that high helps
