We redesigned the CableCam for ODrive
Currently the parts are manufactured - so we will update above with images and videos.
Controller is currently changed to support ODrive ASCII protocol.
Very nice! Make sure to show us a video when you get it working ;D
Okay, cablecam controller can now control the odrive.
I have implemented that as a state machine and using non-blocking calls using the ASCII protocol.
So the idea is that the motor needs to be pre-calibrated because I cannot guarantee it is not hanging on the zip line already and hence might have a gravitational load already.
Once the odrive responds, the encoder calibration is triggered and then the odrive’s configuration values are read.
The vel_limit is used as hard upper limit. So the cablecam controller can define a lower limit but will never send values higher than that. The idea is, in the cablecam controller you might want to set a max speed of 20km/h but the odrive controller would allow for 50km/h.
Now I have to wait for the milled parts to arrive.
Sounds great! Can’t wait to see it in action!
Building it…
