Hello. I have a Raspberry Pi 4 running Open Media Vault and connected to an external 5TB drive. I have enabled FTP on OMV and created a share and users with read/write permissions on that share. I can access the share with FileZilla FTP and directly through Windows using FTP, but odrive will not let me browse the share.
When I linked the FTP serve in odrive’s Manage Storage webUI i got “The FTP server could not validate these credentials” error. I tried various users, FTP, FTPS, Require SSL cert ON and OFF, but the same error always appears. The FTP settings on OMV are the default settings and the FTPS settings currently are:
- Enable SSL/TLS connections - ON
- Require FTP over TLS - ON
- No session reuse required - ON
- Implicit SSL - OFF
I can see the share in Windows Explorer, but when I double-click it, I get “Unable to sync… You do not have sufficient permissions.”
Is there some other setting in OMV I need to change to make this work? Or is there an alternative method to connect to odrive using SMB or NFS that I could configure through OMV?
Thanks
