Ok, Im just gonna copy and paste all of it. I apologize its ugly. Just rebooted, SSH in, plugged and unplugged the Odrive while in RUN Mode, then cycled the Odrive power, but I’m not seeing any messages about the Odrive
pi@raspberrypi:~ $ sudo dmesg -w
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.10.92-v7+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1514 SMP Mon Jan 17 17:36:39 GMT 2022
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2
[ 0.000000] random: fast init done
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Reserved memory: created CMA memory pool at 0x1ec00000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000003b3fffff]
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000003b3fffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000003b3fffff]
[ 0.000000] On node 0 totalpages: 242688
[ 0.000000] DMA zone: 2133 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 242688 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 20 pages/cpu s50828 r8192 d22900 u81920
[ 0.000000] pcpu-alloc: s50828 r8192 d22900 u81920 alloc=20*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 240555
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p7 rootfstype=ext4 fsck.repair=yes rootwait
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 681808K/970752K available (10240K kernel code, 1312K rwdata, 2952K rodata, 1024K init, 862K bss, 26800K reserved, 262144K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 32087 entries in 95 pages
[ 0.000000] ftrace: allocated 95 pages with 6 groups
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] random: get_random_bytes called from start_kernel+0x3ac/0x580 with crng_init=1
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000025] Switching to timer-based delay loop, resolution 52ns
[ 0.000326] Console: colour dummy device 80x30
[ 0.001143] printk: console [tty1] enabled
[ 0.001211] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=192000)
[ 0.001269] pid_max: default: 32768 minimum: 301
[ 0.001482] LSM: Security Framework initializing
[ 0.001743] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.001793] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.003281] cgroup: Disabling memory control group subsystem
[ 0.003570] CPU: Testing write buffer coherency: ok
[ 0.004090] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.005362] Setting up static identity map for 0x100000 - 0x10003c
[ 0.005570] rcu: Hierarchical SRCU implementation.
[ 0.006517] smp: Bringing up secondary CPUs …
[ 0.007710] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.009001] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.010386] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.010544] smp: Brought up 1 node, 4 CPUs
[ 0.010599] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.010631] CPU: All CPU(s) started in HYP mode.
[ 0.010658] CPU: Virtualization extensions available.
[ 0.011654] devtmpfs: initialized
[ 0.029674] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.030025] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.030088] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.040713] pinctrl core: initialized pinctrl subsystem
[ 0.041949] NET: Registered protocol family 16
[ 0.046113] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.051923] audit: initializing netlink subsys (disabled)
[ 0.052240] audit: type=2000 audit(0.050:1): state=initialized audit_enabled=0 res=1
[ 0.052846] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.053793] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.053857] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.054183] Serial: AMBA PL011 UART driver
[ 0.078202] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.090188] raspberrypi-firmware soc:firmware: Attached to firmware from 2022-01-20T13:58:22, variant start
[ 0.100199] raspberrypi-firmware soc:firmware: Firmware hash is bd88f66f8952d34e4e0613a85c7a6d3da49e13e2
[ 0.144533] Kprobes globally optimized
[ 0.149799] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.152133] SCSI subsystem initialized
[ 0.152437] usbcore: registered new interface driver usbfs
[ 0.152524] usbcore: registered new interface driver hub
[ 0.152617] usbcore: registered new device driver usb
[ 0.154590] clocksource: Switched to clocksource arch_sys_counter
[ 1.874269] VFS: Disk quotas dquot_6.6.0
[ 1.874416] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.874676] FS-Cache: Loaded
[ 1.874968] CacheFiles: Loaded
[ 1.875838] simple-framebuffer 3eaa9000.framebuffer: framebuffer at 0x3eaa9000, 0x151800 bytes, mapped to 0x(ptrval)
[ 1.875891] simple-framebuffer 3eaa9000.framebuffer: format=a8r8g8b8, mode=720x480x32, linelength=2880
[ 1.882095] Console: switching to colour frame buffer device 90x30
[ 1.891001] simple-framebuffer 3eaa9000.framebuffer: fb0: simplefb registered!
[ 1.904956] NET: Registered protocol family 2
[ 1.908521] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 1.913916] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 1.920781] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 1.924405] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 1.928090] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.931700] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.935285] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.939044] NET: Registered protocol family 1
[ 1.943224] RPC: Registered named UNIX socket transport module.
[ 1.946727] RPC: Registered udp transport module.
[ 1.950212] RPC: Registered tcp transport module.
[ 1.953666] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.958885] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 1.969722] Initialise system trusted keyrings
[ 1.973484] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 1.986621] zbud: loaded
[ 1.992251] FS-Cache: Netfs ‘nfs’ registered for caching
[ 1.996742] NFS: Registering the id_resolver key type
[ 2.000208] Key type id_resolver registered
[ 2.003549] Key type id_legacy registered
[ 2.006980] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 2.010283] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 2.014838] Key type asymmetric registered
[ 2.018071] Asymmetric key parser ‘x509’ registered
[ 2.021287] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 2.024493] io scheduler mq-deadline registered
[ 2.027637] io scheduler kyber registered
[ 2.042670] bcm2835-rng 3f104000.rng: hwrng registered
[ 2.046348] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 2.053680] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 2.069078] brd: module loaded
[ 2.084438] loop: module loaded
[ 2.089540] Loading iSCSI transport class v2.0-870.
[ 2.094341] libphy: Fixed MDIO Bus: probed
[ 2.097937] usbcore: registered new interface driver lan78xx
[ 2.101167] usbcore: registered new interface driver smsc95xx
[ 2.104210] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 2.835579] Core Release: 2.80a
[ 2.838560] Setting default values for core params
[ 2.841542] Finished setting default values for core params
[ 3.044937] Using Buffer DMA mode
[ 3.047885] Periodic Transfer Interrupt Enhancement - disabled
[ 3.050904] Multiprocessor Interrupt Enhancement - disabled
[ 3.053981] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.057071] Dedicated Tx FIFOs mode
[ 3.060409] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = 9ed04000 dma = 0xded04000 len=9024
[ 3.069127] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 3.083306] dwc_otg: Microframe scheduler enabled
[ 3.083377] WARN::hcd_init_fiq:457: FIQ on core 1
[ 3.088536] WARN::hcd_init_fiq:458: FIQ ASM at 807cc05c length 36
[ 3.093740] WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
[ 3.099029] dwc_otg 3f980000.usb: DWC OTG Controller
[ 3.101813] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 3.104685] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
[ 3.107481] Init: Port Power? op_state=1
[ 3.110212] Init: Power Port (0)
[ 3.113229] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 3.118771] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.121700] usb usb1: Product: DWC OTG Controller
[ 3.124601] usb usb1: Manufacturer: Linux 5.10.92-v7+ dwc_otg_hcd
[ 3.127543] usb usb1: SerialNumber: 3f980000.usb
[ 3.131235] hub 1-0:1.0: USB hub found
[ 3.134135] hub 1-0:1.0: 1 port detected
[ 3.138180] dwc_otg: FIQ enabled
[ 3.138193] dwc_otg: NAK holdoff enabled
[ 3.138205] dwc_otg: FIQ split-transaction FSM enabled
[ 3.138223] Module dwc_common_port init
[ 3.138545] usbcore: registered new interface driver usb-storage
[ 3.141680] mousedev: PS/2 mouse device common for all mice
[ 3.145911] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 3.151533] sdhci: Secure Digital Host Controller Interface driver
[ 3.154489] sdhci: Copyright(c) Pierre Ossman
[ 3.158260] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
[ 3.161960] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[ 3.165343] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.170540] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.174049] hid: raw HID events driver (C) Jiri Kosina
[ 3.177358] usbcore: registered new interface driver usbhid
[ 3.180432] usbhid: USB HID core driver
[ 3.188769] Initializing XFRM netlink socket
[ 3.191843] NET: Registered protocol family 17
[ 3.195074] Key type dns_resolver registered
[ 3.198607] Registering SWP/SWPB emulation handler
[ 3.201783] registered taskstats version 1
[ 3.204733] Loading compiled-in X.509 certificates
[ 3.208454] Key type ._fscrypt registered
[ 3.211205] Key type .fscrypt registered
[ 3.213873] Key type fscrypt-provisioning registered
[ 3.228396] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 3.231267] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 114, base_baud = 0) is a PL011 rev2
[ 3.239349] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 3.244091] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 3.247181] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
[ 3.264750] Indeed it is in host mode hprt0 = 00021501
[ 3.329586] sdhost: log_buf @ (ptrval) (ded07000)
[ 3.370900] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 3.375510] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.379979] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.382708] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 3.388371] of_cfs_init
[ 3.391215] of_cfs_init: OK
[ 3.395120] Waiting for root device /dev/mmcblk0p7…
[ 3.408453] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 3.448125] mmc0: host does not support reading read-only switch, assuming write-enable
[ 3.452810] mmc0: Problem switching card into high-speed mode!
[ 3.457056] mmc0: new SDHC card at address 0001
[ 3.460841] mmcblk0: mmc0:0001 00000 29.1 GiB
[ 3.469888] mmcblk0: p1 p2 < p5 p6 p7 >
[ 3.474678] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 3.477665] Indeed it is in host mode hprt0 = 00001101
[ 3.560230] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
[ 3.566136] VFS: Mounted root (ext4 filesystem) readonly on device 179:7.
[ 3.583217] devtmpfs: mounted
[ 3.591439] mmc1: new high speed SDIO card at address 0001
[ 3.596144] Freeing unused kernel memory: 1024K
[ 3.605116] Run /sbin/init as init process
[ 3.607899] with arguments:
[ 3.607911] /sbin/init
[ 3.607922] with environment:
[ 3.607933] HOME=/
[ 3.607944] TERM=linux
[ 3.715001] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcdDevice= 2.00
[ 3.720851] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.724759] hub 1-1:1.0: USB hub found
[ 3.727998] hub 1-1:1.0: 5 ports detected
[ 4.044660] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 4.175006] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
[ 4.181578] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.188043] smsc95xx v2.0.0
[ 4.557101] systemd[1]: System time before build time, advancing clock.
[ 4.628519] libphy: smsc95xx-mdiobus: probed
[ 4.632967] smsc95xx 1-1.1:1.0 eth0: register ‘smsc95xx’ at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:37:64:20
[ 4.741002] NET: Registered protocol family 10
[ 4.746284] Segment Routing with IPv6
[ 4.842527] systemd[1]: systemd 247.3-6+rpi1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 4.860322] systemd[1]: Detected architecture arm.
[ 4.899130] systemd[1]: Set hostname to .
[ 6.107426] systemd[1]: Queued start job for default target Graphical Interface.
[ 6.113503] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.120146] systemd[1]: Created slice system-getty.slice.
[ 6.128651] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.133638] systemd[1]: Created slice system-modprobe.slice.
[ 6.141685] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.146615] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 6.155378] systemd[1]: Created slice User and Session Slice.
[ 6.163565] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 6.171843] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 6.181207] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 6.193586] systemd[1]: Reached target Local Encrypted Volumes.
[ 6.202421] systemd[1]: Reached target Paths.
[ 6.210989] systemd[1]: Reached target Slices.
[ 6.219357] systemd[1]: Reached target Swap.
[ 6.228649] systemd[1]: Listening on Syslog Socket.
[ 6.237397] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 6.245872] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 6.255295] systemd[1]: Listening on Journal Audit Socket.
[ 6.264081] systemd[1]: Listening on Journal Socket (/dev/log).
[ 6.273032] systemd[1]: Listening on Journal Socket.
[ 6.283160] systemd[1]: Listening on udev Control Socket.
[ 6.291537] systemd[1]: Listening on udev Kernel Socket.
[ 6.299947] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 6.311308] systemd[1]: Mounting POSIX Message Queue File System…
[ 6.324725] systemd[1]: Mounting RPC Pipe File System…
[ 6.338575] systemd[1]: Mounting Kernel Debug File System…
[ 6.352717] systemd[1]: Mounting Kernel Trace File System…
[ 6.361613] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 6.385863] systemd[1]: Starting Restore / save the current clock…
[ 6.399932] systemd[1]: Starting Set the console keyboard layout…
[ 6.414314] systemd[1]: Starting Create list of static device nodes for the current kernel…
[ 6.434505] systemd[1]: Starting Load Kernel Module configfs…
[ 6.451769] systemd[1]: Starting Load Kernel Module drm…
[ 6.467305] systemd[1]: Starting Load Kernel Module fuse…
[ 6.509133] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 6.522266] systemd[1]: Starting File System Check on Root Device…
[ 6.545471] systemd[1]: Starting Journal Service…
[ 6.578929] fuse: init (API version 7.32)
[ 6.579441] systemd[1]: Starting Load Kernel Modules…
[ 6.613287] systemd[1]: Starting Coldplug All udev Devices…
[ 6.654147] systemd[1]: Mounted POSIX Message Queue File System.
[ 6.665579] systemd[1]: Mounted RPC Pipe File System.
[ 6.674207] systemd[1]: Mounted Kernel Debug File System.
[ 6.682734] systemd[1]: Mounted Kernel Trace File System.
[ 6.693433] systemd[1]: Finished Restore / save the current clock.
[ 6.719804] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 6.733975] systemd[1]: modprobe@configfs.service: Succeeded.
[ 6.739198] systemd[1]: Finished Load Kernel Module configfs.
[ 6.748815] systemd[1]: modprobe@drm.service: Succeeded.
[ 6.753585] systemd[1]: Finished Load Kernel Module drm.
[ 6.763171] systemd[1]: modprobe@fuse.service: Succeeded.
[ 6.768176] systemd[1]: Finished Load Kernel Module fuse.
[ 6.777771] systemd[1]: Finished Load Kernel Modules.
[ 6.803177] systemd[1]: Mounting FUSE Control File System…
[ 6.817507] systemd[1]: Mounting Kernel Configuration File System…
[ 6.843752] systemd[1]: Started File System Check Daemon to report status.
[ 6.863248] systemd[1]: Starting Apply Kernel Variables…
[ 6.879069] systemd[1]: Started Journal Service.
[ 7.070360] EXT4-fs (mmcblk0p7): re-mounted. Opts: (null)
[ 7.208944] systemd-journald[126]: Received client request to flush runtime journal.
[ 7.225716] systemd-journald[126]: File /var/log/journal/38816bac59f648bdb8644099c935682c/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 8.680160] mc: Linux media interface: v0.10
[ 8.739546] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.750805] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 8.750889] [vc_sm_connected_init]: start
[ 8.754493] videodev: Linux video capture interface: v2.00
[ 8.765638] [vc_sm_connected_init]: installed successfully
[ 8.808138] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.852753] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.885397] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.913205] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 8.917714] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.921493] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 8.924454] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 8.927325] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 8.927366] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 8.927391] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 8.927412] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 8.927433] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 8.939954] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 8.940396] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 8.940799] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 8.941095] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 8.941124] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 8.941149] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 8.941170] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 8.941190] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 8.941396] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 8.951197] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 8.951253] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 8.965093] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 8.965153] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 8.999826] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 9.016836] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 9.016892] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 9.028256] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 9.028311] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 9.029114] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 9.235066] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 9.431690] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 9.571863] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[ 9.637270] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
[ 9.674152] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[ 9.675768] usbcore: registered new interface driver brcmfmac
[ 9.968521] random: crng init done
[ 9.968539] random: 7 urandom warning(s) missed due to ratelimiting
[ 10.024500] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[ 10.024748] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[ 10.048877] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Jul 19 2021 03:24:18 version 7.45.98 (TOB) (56df937 CY) FWID 01-8e14b897
[ 10.145353] checking generic (3eaa9000 151800) vs hw (0 ffffffff)
[ 10.145379] fb0: switching to vc4drmfb from simple
[ 10.146013] Console: switching to colour dummy device 80x30
[ 10.153078] vc4-drm soc:gpu: bound 3f400000.hvs (ops vc4_hvs_ops [vc4])
[ 10.154096] Registered IR keymap rc-cec
[ 10.154379] rc rc0: vc4 as /devices/platform/soc/3f902000.hdmi/rc/rc0
[ 10.154724] input: vc4 as /devices/platform/soc/3f902000.hdmi/rc/rc0/input0
[ 10.731599] vc4-drm soc:gpu: bound 3f400000.hvs (ops vc4_hvs_ops [vc4])
[ 10.737431] Registered IR keymap rc-cec
[ 10.737708] rc rc0: vc4 as /devices/platform/soc/3f902000.hdmi/rc/rc0
[ 10.738050] input: vc4 as /devices/platform/soc/3f902000.hdmi/rc/rc0/input1
[ 10.751576] vc4-drm soc:gpu: bound 3f902000.hdmi (ops vc4_hdmi_ops [vc4])
[ 10.751987] vc4-drm soc:gpu: bound 3f004000.txp (ops vc4_txp_ops [vc4])
[ 10.752333] vc4-drm soc:gpu: bound 3f206000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 10.752637] vc4-drm soc:gpu: bound 3f207000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 10.752933] vc4-drm soc:gpu: bound 3f807000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 10.753194] vc4-drm soc:gpu: bound 3fc00000.v3d (ops vc4_v3d_ops [vc4])
[ 10.786839] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 0
[ 10.787445] vc4-drm soc:gpu: [drm] Cannot find any crtc or sizes
[ 12.879031] uart-pl011 3f201000.serial: no DMA platform data
[ 12.939219] 8021q: 802.1Q VLAN Support v1.8
[ 13.374730] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 13.758239] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 14.356303] SMSC LAN8700 usb-001:003:01: attached PHY driver [SMSC LAN8700] (mii_bus:phy_addr=usb-001:003:01, irq=POLL)
[ 14.356560] smsc95xx 1-1.1:1.0 eth0: hardware isn’t capable of remote wakeup
[ 14.365494] smsc95xx 1-1.1:1.0 eth0: Link is Down
[ 15.186621] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 18.475916] Bluetooth: Core ver 2.22
[ 18.476049] NET: Registered protocol family 31
[ 18.476061] Bluetooth: HCI device and connection manager initialized
[ 18.476092] Bluetooth: HCI socket layer initialized
[ 18.476111] Bluetooth: L2CAP socket layer initialized
[ 18.476140] Bluetooth: SCO socket layer initialized
[ 18.497450] Bluetooth: HCI UART driver ver 2.3
[ 18.497464] Bluetooth: HCI UART protocol H4 registered
[ 18.497545] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 18.497736] Bluetooth: HCI UART protocol Broadcom registered
[ 19.273712] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 19.273732] Bluetooth: BNEP filters: protocol multicast
[ 19.273759] Bluetooth: BNEP socket layer initialized
[ 19.305112] NET: Registered protocol family 38
[ 19.349630] cryptd: max_cpu_qlen set to 1000
[ 20.955608] vc4-drm soc:gpu: [drm] Cannot find any crtc or sizes
[ 33.754664] cam1-reg: disabling
[ 33.754689] cam-dummy-reg: disabling
