I would like to connect my RasPi 3 Model B+, 2017 to the oDrive 3.5, but I fail with the USB path specification, maybe because I’m not that used to Python code yet. The answer I get is
$ ./odrivetool --path /dev/bus/usb/001/005
ODrive control utility v0.4.8.dev
Developer Preview
If you find issues, please report them
on https://github.com/madcowswe/ODrive/issues
or better yet, submit a pull request to fix it.
File "./odrivetool", line 137, in <module>
odrive.shell.launch_shell(args, logger, app_shutdown_token)
File "/home/dlguser/odrive/ODrive/tools/odrive/shell.py", line 90, in launch_shell
branding_short="odrv", branding_long="ODrive")
File "/home/dlguser/odrive/ODrive/Firmware/fibre/python/fibre/shell.py", line 64, in launch_shell
logger=logger)
File "/home/dlguser/odrive/ODrive/Firmware/fibre/python/fibre/discovery.py", line 110, in find_all
raise Exception("Invalid path spec \"{}\"".format(search_spec))
Exception: Invalid path spec "/dev/bus/usb/001/005"
I got the USB path from
$lsusb
but maybe I have to change it?
Without the path command, I also get the error
Exception: Invalid path spec "usb"
Do you have any idea what I could do? Thank you very much!
