Hi im trying to setup a belt driven linear axis for a wire edm machine using a 190kv 14 pole sensored motor and a .001mm linear encoder. Im not able to calibrate the motor with the default calibration cycle due to the travel limits of the axis being equivalent to about 5 motor turns (40mm/rev 200mm total travel). I have the hall sensors set as the commutation encoder and the linear encoder set as an incremental load encoder with index pulses.
Is there a way to change to calibration distance to allow the motor to finish calibration? or is it possible to calibrate the motor separate from the linear encoder then recombine them?
