Hello all,
I was using Sensor-less mode because I was waiting for he encoders and the motors were working with some minor issues when stopping abruptly.
I have received the AMT102-V encoders and have been trying the past couple of days to use the ODrive tool to control the motors but to no avail. It is time I ask for some help!
So the current setup is:
Odrive 24v powered by a PSU at 12.5V 60A( can go higher but the motors are limited to 15v and don’t want to risk it!)
Turnigy Aerodrive SK3 - 2830-920kv (out runner)
and finally the AMT102-V encoder.
The encoder came without a wire so I made my own using the housings and pins required as mentioned in its datasheet and solder them direlty onto the Odrive.
What I have tried so far is :
reset the odrive and calibrate it
odrv1.erase_configuration()
odrv1.reboot()
odrv1.axis0.encoder.config.use_index = True
odrv1.axis0.requested_state = AXIS_STATE_FULL_CALIBRATION_SEQUENCE
odrv1.axis0.encoder.config.pre_calibrated = True
odrv1.axis0.motor.config.pre_calibrated = True
odrv1.axis0.config.startup_encoder_index_search = True
odrv1.axis0.config.startup_closed_loop_control = True
odrv1.save_configuration()
odrv1.reboot() -
after calibration enter the closed loop state
Try setting a pos_setpoint (eg 10000) or vel_setpoint — Nothing happens or I get the ERROR_OVERSPEED)
Increase the vel_limit to 100000 - This solves the overspeed, however it starts vibrating and the motor isn’t moving at all.
The above steps were with the default values.
I have tried the exact same steps with the values ( gains ) I got from the Sensoreless setup and increase the motor.config.current_lim to 20. I know that the motors were working with these values.
Here is the output from the odrv.axis:
In [77]: odrv1.axis0
Out[77]:
error = 0x0000 (int)
step_dir_active = False (bool)
current_state = 1 (int)
requested_state = 0 (int)
loop_counter = 32738166 (int)
lockin_state = 0 (int)
config:
startup_encoder_index_search = True (bool)
startup_closed_loop_control = True (bool)
counts_per_step = 2.0 (float)
step_gpio_pin = 1 (int)
dir_gpio_pin = 2 (int)
calibration_lockin: ...
sensorless_ramp: ...
general_lockin: ...
motor:
armed_state = 0 (int)
is_calibrated = True (bool)
current_meas_phB = -0.28109169006347656 (float)
current_meas_phC = 0.035080693662166595 (float)
DC_calib_phB = -1.652514934539795 (float)
DC_calib_phC = 0.08589068055152893 (float)
phase_current_rev_gain = 0.02500000037252903 (float)
thermal_current_lim = 48.00704574584961 (float)
get_inverter_temp()
current_control: ...
gate_driver: ...
timing_log: ...
config: ...
controller:
pos_setpoint = -7610.765625 (float)
vel_setpoint = 0.0 (float)
vel_integrator_current = -0.3915861248970032 (float)
vel_ramp_target = 0.0 (float)
vel_ramp_enable = False (bool)
config: ...
set_pos_setpoint(pos_setpoint: float, vel_feed_forward: float, current_feed_forward: float)
move_to_pos(pos_setpoint: float)
move_incremental(displacement: float, from_goal_point: bool)
encoder:
is_ready = True (bool)
index_found = True (bool)
shadow_count = -5636 (int)
count_in_cpr = 2556 (int)
interpolation = 0.5 (float)
phase = 0.9716787338256836 (float)
pos_estimate = -5635.765625 (float)
pos_cpr = 2556.234375 (float)
hall_state = 0 (int)
vel_estimate = 0.0 (float)
calib_scan_response = 9329.0 (float)
config: ...
set_linear_count(count: int)
sensorless_estimator:
phase = -2.2962546348571777 (float)
pll_pos = -2.297368049621582 (float)
vel_estimate = 0.04372486472129822 (float)
config: ...
trap_traj:
config: ...
watchdog_feed()
HW / FW versions:
hw_version_major = 3 (int)
hw_version_minor = 6 (int)
hw_version_variant = 24 (int)
fw_version_major = 0 (int)
fw_version_minor = 4 (int)
fw_version_revision = 11 (int)
fw_version_unreleased = 0 (int)
Also, I have another question about the tuning procedure. Do you enter the closed loop mode and set a vel or pos_setpoint so it will be ‘energized’ and then you start the tuning? If not could someone please clarify the steps before initializing the tuning procedure?
Thank you in advance,
Michail
