Hi guys,
I am compiling the new version 0.5.2 on a ubuntu. I have successfully compiled the early version.
however have a problem with the compiling and I have no clue how to fix it. The error information is like following:
board version: v3.5-48V
Firmware version 0.5.2-dev (fw-v0.5.2-18-ge52d3d90)
Initializing .tup in /home/cai/ODrive0.5.2/Firmware
.tup repository initialized.
0) new variant: tup.config
100%
not using pkgconf
Using python command “python3 -B”
[ ETA~=<1s Remaining=0 ] 100%
- python3 -B interface_generator_stub.py --definitions odrive-interface.yaml --generate-endpoints ODrive3 --template fibre-cpp/endpoints_template.j2 --output autogen/endpoints.hpp
No module named ‘jinja2’
Note that there are new compile-time dependencies since around v0.5.1.
Check out https://github.com/madcowswe/ODrive/blob/devel/docs/developer-guide.md#prerequisites for details.
*** tup messages ***
*** Command ID=404 failed with return value 1
- python3 -B interface_generator_stub.py --definitions odrive-interface.yaml --template fibre-cpp/function_stubs_template.j2 --output autogen/function_stubs.hpp
*** Command ID=402 failed with return value 1
- python3 -B interface_generator_stub.py --definitions odrive-interface.yaml --template fibre-cpp/type_info_template.j2 --output autogen/type_info.hpp
*** Command ID=406 failed with return value 1
- python3 -B interface_generator_stub.py --definitions odrive-interface.yaml --template fibre-cpp/interfaces_template.j2 --output autogen/interfaces.hpp
*** Command ID=400 failed with return value 1
[ ETA~=5s Remaining=99 Active=0 ] 3%
*** tup: 4 jobs failed.
Makefile:31: recipe for target ‘all’ failed
make: *** [all] Error 1
does anybody have an idea what happened and how to fix it?
