lsusb
Bus 002 Device 004: ID 05e3:0727 Genesys Logic, Inc. microSD Reader/Writer
Bus 002 Device 003: ID 0a5c:219a Broadcom Corp.
Bus 002 Device 006: ID 0483:df11 STMicroelectronics STM Device in DFU Mode
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 003: ID 2232:1018 Silicon Motion
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
sudo odrivetool
ODrive control utility v0.4.9
/usr/local/lib/python3.6/dist-packages/fibre/shell.py:104: RuntimeWarning: coroutine ‘InteractiveShell.run_code’ was never awaited
console.runcode(‘import sys’)
/usr/local/lib/python3.6/dist-packages/fibre/shell.py:105: RuntimeWarning: coroutine ‘InteractiveShell.run_code’ was never awaited
console.runcode(‘superexcepthook = sys.excepthook’)
/usr/local/lib/python3.6/dist-packages/fibre/shell.py:106: RuntimeWarning: coroutine ‘InteractiveShell.run_code’ was never awaited
console.runcode(‘def newexcepthook(ex_class,ex,trace):\n’
/usr/local/lib/python3.6/dist-packages/fibre/shell.py:109: RuntimeWarning: coroutine ‘InteractiveShell.run_code’ was never awaited
console.runcode(‘sys.excepthook=newexcepthook’)
Please connect your ODrive.
i installed odrivetool in latest kubuntu 18.04, but odrivetool doesn’t connecting to my odrive.
I followed getting started document and no errors in this stage.
