Control/Input Mode Commands Only Work on Teensy Backend — Fails When Using ODriveHardwareCAN.hpp
I’ve been testing the ODrive CAN example on both a Teensy 4.1 and an Arduino Uno R4 WiFi, and I’ve run into a consistent difference between the two CAN backends.
When I compile using the Teensy CAN backend, everything works correctly. The ODrive switches into the requested input/control modes, and I can see over USB that it actually enters trap‑traj mode. Trap‑traj limits also apply correctly.
When I switch to the Arduino built‑in CAN backend (which uses ODriveHardwareCAN.hpp), those same commands stop working. In the attached code I’m setting the input mode to passthrough, but I’ve also tested position‑filter, trap‑traj, inactive, etc., and none of them take effect. Trap‑traj limit commands also don’t seem to apply. The ODrive never reflects the requested mode changes when using the Arduino backend.
The sketch is the same in both cases — the only difference is which CAN backend is compiled in. This makes it look like the issue is isolated to ODriveHardwareCAN.hpp.
Attaching the code I used for testing in case it helps reproduce the issue.
#include <Arduino.h>
#include "ODriveCAN.h"
// Documentation for this example can be found here:
// https://docs.odriverobotics.com/v/latest/guides/arduino-can-guide.html
/* Configuration of example sketch -------------------------------------------*/
// CAN bus baudrate. Make sure this matches for every device on the bus
#define CAN_BAUDRATE 1000000
// ODrive node_id for odrv0
#define ODRV0_NODE_ID 0
// Uncomment below the line that corresponds to your hardware.
// See also "Board-specific settings" to adapt the details for your hardware setup.
#define IS_TEENSY_BUILTIN // Teensy boards with built-in CAN interface (e.g. Teensy 4.1). See below to select which interface to use.
// #define IS_ARDUINO_BUILTIN // Arduino boards with built-in CAN interface (e.g. Arduino Uno R4 Minima)
// #define IS_MCP2515 // Any board with external MCP2515 based extension module. See below to configure the module.
// #define IS_STM32_BUILTIN // STM32 boards with built-in CAN interface (e.g. STM32F4 Discovery).
// #define IS_ESP32_TWAI // ESP32 boards with built-in TWAI (CAN) interface. Directly uses the ESP-IDF TWAI driver.
/* Board-specific includes ---------------------------------------------------*/
#if defined(IS_TEENSY_BUILTIN) + defined(IS_ARDUINO_BUILTIN) + defined(IS_MCP2515) + defined(IS_STM32_BUILTIN) + defined(IS_ESP32_TWAI) != 1
#warning "Select exactly one hardware option at the top of this file."
#if CAN_HOWMANY > 0 || CANFD_HOWMANY > 0
#warning "guessing that this uses HardwareCAN"
#else
#error "cannot guess hardware version"
#endif
#endif
#ifdef IS_ARDUINO_BUILTIN
// See https://github.com/arduino/ArduinoCore-API/blob/master/api/HardwareCAN.h
// and https://github.com/arduino/ArduinoCore-renesas/tree/main/libraries/Arduino_CAN
#include <Arduino_CAN.h>
#include <ODriveHardwareCAN.hpp>
#endif // IS_ARDUINO_BUILTIN
#ifdef IS_MCP2515
// See https://github.com/sandeepmistry/arduino-CAN/
#include "MCP2515.h"
#include "ODriveMCPCAN.hpp"
#endif // IS_MCP2515
#ifdef IS_TEENSY_BUILTIN
// See https://github.com/tonton81/FlexCAN_T4
// clone https://github.com/tonton81/FlexCAN_T4.git into /src
#include <FlexCAN_T4.h>
#include "ODriveFlexCAN.hpp"
struct ODriveStatus; // hack to prevent teensy compile error
#endif // IS_TEENSY_BUILTIN
#ifdef IS_STM32_BUILTIN
// See https://github.com/pazi88/STM32_CAN
#include <STM32_CAN.h>
#include "ODriveSTM32CAN.hpp"
#endif // IS_STM32_BUILTIN
#ifdef IS_ESP32_TWAI
// See https://docs.espressif.com/projects/esp-idf/en/stable/esp32/api-reference/peripherals/twai.html
#include "driver/twai.h"
#include "ODriveESP32TWAI.hpp"
#endif // IS_ESP32_TWAI
/* Board-specific settings ---------------------------------------------------*/
/* Teensy */
FlexCAN_T4<CAN1, RX_SIZE_256, TX_SIZE_16> can_intf;
bool setupCan() {
  can_intf.begin();
  can_intf.setBaudRate(CAN_BAUDRATE);
  can_intf.setMaxMB(16);
  can_intf.enableFIFO();
  can_intf.enableFIFOInterrupt();
  can_intf.onReceive(onCanMessage);
  return true;
/* MCP2515-based extension modules -*/
#ifdef IS_MCP2515
MCP2515Class& can_intf = CAN;
// chip select pin used for the MCP2515
#define MCP2515_CS 10
// interrupt pin used for the MCP2515
// NOTE: not all Arduino pins are interruptable, check the documentation for your board!
#define MCP2515_INT 2
// freqeuncy of the crystal oscillator on the MCP2515 breakout board.
// common values are: 16 MHz, 12 MHz, 8 MHz
#define MCP2515_CLK_HZ 8000000
static inline void receiveCallback(int packet_size) {
  if (packet_size > 8) {
    return; // not supported
  CanMsg msg = {.id = (unsigned int)CAN.packetId(), .len = (uint8_t)packet_size};
  CAN.readBytes(msg.buffer, packet_size);
  onCanMessage(msg);
bool setupCan() {
  // configure and initialize the CAN bus interface
  CAN.setPins(MCP2515_CS, MCP2515_INT);
  CAN.setClockFrequency(MCP2515_CLK_HZ);
  if (!CAN.begin(CAN_BAUDRATE)) {
    return false;
  CAN.onReceive(receiveCallback);
  return true;
/* Arduinos with built-in CAN */
HardwareCAN& can_intf = CAN;
bool setupCan() {
  return can_intf.begin((CanBitRate)CAN_BAUDRATE);
#endif
/* STM32 boards with built-in CAN */
STM32_CAN Can1( CAN1 );
STM32_CAN& can_intf = Can1;
bool setupCan() {
  can_intf.begin();
  return true;
/* ESP32 boards with built-in TWAI (CAN) */
// Pins used to connect to CAN bus transceiver
#define ESP32_TWAI_TX_PIN 26
#define ESP32_TWAI_RX_PIN 25
ESP32TWAIIntf can_intf;
bool setupCan() {
    twai_general_config_t g_config = TWAI_GENERAL_CONFIG_DEFAULT(
        (gpio_num_t)ESP32_TWAI_TX_PIN,
        (gpio_num_t)ESP32_TWAI_RX_PIN,
        TWAI_MODE_NORMAL
    twai_timing_config_t t_config;
    switch (CAN_BAUDRATE) {
        case 1000000: t_config = TWAI_TIMING_CONFIG_1MBITS(); break;
        case 800000:  t_config = TWAI_TIMING_CONFIG_800KBITS(); break;
        case 500000:  t_config = TWAI_TIMING_CONFIG_500KBITS(); break;
        case 250000:  t_config = TWAI_TIMING_CONFIG_250KBITS(); break;
        case 125000:  t_config = TWAI_TIMING_CONFIG_125KBITS(); break;
        case 100000:  t_config = TWAI_TIMING_CONFIG_100KBITS(); break;
        case 50000:   t_config = TWAI_TIMING_CONFIG_50KBITS(); break;
        case 25000:   t_config = TWAI_TIMING_CONFIG_25KBITS(); break;
        default:      t_config = TWAI_TIMING_CONFIG_250KBITS(); break;
    twai_filter_config_t f_config = TWAI_FILTER_CONFIG_ACCEPT_ALL();
    if (twai_driver_install(&g_config, &t_config, &f_config) != ESP_OK) {
        return false;
    if (twai_start() != ESP_OK) {
        twai_driver_uninstall();
        return false;
    return true;
/* Example sketch ------------------------------------------------------------*/
// Instantiate ODrive objects
ODriveCAN odrv0(wrap_can_intf(can_intf), ODRV0_NODE_ID); // Standard CAN message ID
ODriveCAN* odrives[] = {&odrv0}; // Make sure all ODriveCAN instances are accounted for here
struct ODriveUserData {
  Heartbeat_msg_t last_heartbeat;
  bool received_heartbeat = false;
  Get_Encoder_Estimates_msg_t last_feedback;
  bool received_feedback = false;
// Keep some application-specific user data for every ODrive.
ODriveUserData odrv0_user_data;
// Called every time a Heartbeat message arrives from the ODrive
void onHeartbeat(Heartbeat_msg_t& msg, void* user_data) {
  ODriveUserData* odrv_user_data = static_cast<ODriveUserData*>(user_data);
  odrv_user_data->last_heartbeat = msg;
  odrv_user_data->received_heartbeat = true;
// Called every time a feedback message arrives from the ODrive
void onFeedback(Get_Encoder_Estimates_msg_t& msg, void* user_data) {
  odrv_user_data->last_feedback = msg;
  odrv_user_data->received_feedback = true;
// Called for every message that arrives on the CAN bus
void onCanMessage(const CanMsg& msg) {
  for (auto odrive: odrives) {
    onReceive(msg, *odrive);
void setup() {
  Serial.begin(115200);
  // Wait for up to 3 seconds for the serial port to be opened on the PC side.
  // If no PC connects, continue anyway.
  for (int i = 0; i < 30 && !Serial; ++i) {
    delay(100);
  delay(200);
  Serial.println("Starting ODriveCAN demo");
  // Register callbacks for the heartbeat and encoder feedback messages
  odrv0.onFeedback(onFeedback, &odrv0_user_data);
  odrv0.onStatus(onHeartbeat, &odrv0_user_data);
  // Configure and initialize the CAN bus interface. This function depends on
  // your hardware and the CAN stack that you're using.
  if (!setupCan()) {
    Serial.println("CAN failed to initialize: reset required");
    while (true); // spin indefinitely
  Serial.println("Waiting for ODrive...");
  while (!odrv0_user_data.received_heartbeat) {
    pumpEvents(can_intf);
  Serial.println("found ODrive");
  // request bus voltage and current (1sec timeout)
  Serial.println("attempting to read bus voltage and current");
  Get_Bus_Voltage_Current_msg_t vbus;
  if (!odrv0.request(vbus, 1000)) {
    Serial.println("vbus request failed!");
  Serial.print("DC voltage [V]: ");
  Serial.println(vbus.Bus_Voltage);
  Serial.print("DC current [A]: ");
  Serial.println(vbus.Bus_Current);
  odrv0.setControllerMode(ODriveControlMode::CONTROL_MODE_POSITION_CONTROL, ODriveInputMode::INPUT_MODE_PASSTHROUGH);
  delay(1000);
  Serial.println("Enabling closed loop control...");
  while (odrv0_user_data.last_heartbeat.Axis_State != ODriveAxisState::AXIS_STATE_CLOSED_LOOP_CONTROL) {
    odrv0.clearErrors();
    delay(1);
    odrv0.setState(ODriveAxisState::AXIS_STATE_CLOSED_LOOP_CONTROL);
    // Pump events for 150ms. This delay is needed for two reasons;
    // 1. If there is an error condition, such as missing DC power, the ODrive might
    //    briefly attempt to enter CLOSED_LOOP_CONTROL state, so we can't rely
    //    on the first heartbeat response, so we want to receive at least two
    //    heartbeats (100ms default interval).
    // 2. If the bus is congested, the setState command won't get through
    //    immediately but can be delayed.
    for (int i = 0; i < 15; ++i) {
      delay(10);
  Serial.println("ODrive running!");
void loop() {
  pumpEvents(can_intf); // This is required on some platforms to handle incoming feedback CAN messages
                        // Note that on MCP2515-based platforms, this will delay for a fixed 10ms.
                        // This has been found to reduce the number of dropped messages, however it can be removed
                        // for applications requiring loop times over 100Hz.
  float SINE_PERIOD = 2.0f; // Period of the position command sine wave in seconds
  float t = 0.001 * millis();
  float phase = t * (TWO_PI / SINE_PERIOD);
  odrv0.setPosition(
    sin(phase), // position
    cos(phase) * (TWO_PI / SINE_PERIOD) // velocity feedforward (optional)
  // print position and velocity for Serial Plotter
  if (odrv0_user_data.received_feedback) {
    Get_Encoder_Estimates_msg_t feedback = odrv0_user_data.last_feedback;
    odrv0_user_data.received_feedback = false;
    Serial.print("odrv0-pos:");
    Serial.print(feedback.Pos_Estimate);
    Serial.print(",");
    Serial.print("odrv0-vel:");
    Serial.println(feedback.Vel_Estimate);
Interesting, thanks for the info! Just checking, other CAN communication/controls work? e.g. the Arduino can send setpoints, receive heartbeats, etc?
Yes — the example works fine as‑is. The issue only shows up when I try to use functions that aren’t part of the stock example, like setControllerMode() or setTrapezoidalAccelLimits(). Those calls don’t behave correctly when compiling with IS_ARDUINO_BUILTIN (For Arduino Uno R4 WiFi), but everything works normally when using IS_TEENSY_BUILTIN (For Teensy 4.1).
Looks like this is because the Teensy has a larger outgoing buffer than the Arduino does – if the Arduino tries to send a message and it causes a collision, it silently drops the message instead of . Try calling pumpEvents() immediately before calling the function. You could also read-back the value from the ODrive, and retry if it doesn’t write correctly, example:
uint8_t desired_control_mode = CONTROL_MODE_POSITION_CONTROL;
uint8_t desired_input_mode = INPUT_MODE_PASSTHROUGH;
Set_Controller_Mode_msg_t controller_mode_msg;
do {
  pumpEvents();
  odrv0.setControllerMode(desired_control_mode, desired_input_mode);
  odrv0.request(controller_mode_msg);
} while ((controller_mode_msg.Control_Mode != desired_control_mode) || (controller_mode_msg.Input_Mode != desired_input_mode));
