I have my odrive interfaced to the Arduino via uart communication. Position and velocity control work well. However when I try to do current control using odrive.SetCurrent(0, 10.0f) the motor moves a little and then it seeems like it hit a safety switch and stops powering the motor. I have to restart ODrive to continue using it.
I have used the following commands to remove any current or velocity limits but it doesn’t seem to have helped.
odrive_serial << “w axis” << 0 << “.controller.enable_current_mode_current_limit = False” << ‘\n’;
odrive_serial << “w axis” << 0 << “.controller.enable_current_mode_vel_limit = False” << ‘\n’;
Any advice is appreciated!
