Hello, I’m using the 24V ODrive v3.5 to power a T-Motor U3 KV700. I just went through the getting started guide, tuned the position controller, and am going through the rest of the documentation to see how things work.
One of the first things I tried was increasing motor.config.current_lim to see how much I could push the system (still keeping it in position control but applying a disturbance and checking the applied current). When I set motor.config.current_lim any higher than the default 10A (right now I’m trying 20A) and apply a disturbance, the current (both in Iq_measured and Iq_setpoint) saturates at 11.5 (11.500000953674316) or -12.5 (-12.537500381469727) depending on the direction I apply a disturbance. I’ve looked around in the documentation to see what else might be causing this but haven’t found anything. My power supply isn’t saturating either. Anyone know what I’m missing?
Controller settings in odrv0.axis0.controller:
error = 0x0000 (int)
pos_setpoint = -21.984375 (float)
vel_setpoint = 0.0 (float)
vel_integrator_current = 0.0 (float)
current_setpoint = 0.5 (float)
vel_ramp_target = 0.0 (float)
vel_ramp_enable = False (bool)
config:
control_mode = 3 (int)
pos_gain = 50.0 (float)
vel_gain = 0.0003000000142492354 (float)
vel_integrator_gain = 0.0 (float)
vel_limit = 40000.0 (float)
vel_limit_tolerance = 0.0 (float)
setpoints_in_cpr = False (bool)
set_pos_setpoint(pos_setpoint: float, vel_feed_forward: float, current_feed_forward: float)
move_to_pos(goal_point: float)
Motor settings in odrv0.axis0.motor:
armed_state = 3 (int)
is_calibrated = True (bool)
current_meas_phB = -0.2519184350967407 (float)
current_meas_phC = 0.2588951587677002 (float)
DC_calib_phB = -1.4805927276611328 (float)
DC_calib_phC = -2.272979974746704 (float)
phase_current_rev_gain = 0.02500000037252903 (float)
current_control:
p_gain = 0.02000526711344719 (float)
i_gain = 103.69937896728516 (float)
v_current_control_integral_d = -0.011798991821706295 (float)
v_current_control_integral_q = 0.0824267566204071 (float)
Ibus = 0.0017087971791625023 (float)
final_v_alpha = 0.014038833789527416 (float)
final_v_beta = -0.05565432086586952 (float)
Iq_setpoint = -0.12379783391952515 (float)
Iq_measured = 0.11780458688735962 (float)
max_allowed_current = 60.75 (float)
overcurrent_trip_level = 67.5 (float)
config:
pre_calibrated = True (bool)
pole_pairs = 7 (int)
calibration_current = 5.0 (float)
phase_inductance = 2.0005267288070172e-05 (float)
phase_resistance = 0.10369938611984253 (float)
direction = -1 (int)
motor_type = 0 (int)
current_lim = 25.0 (float)
