I just got my odrive 3.6, wired it up, and i get nothing on the usb. zadig does not see it. the dip switch was taped over but i took that off and set it to dfu, still nothing on the USB. So i installed openocd and used the st-link v2 - wont go into that process - i have a gold st-link with different pinouts. got this:
xPack OpenOCD, 64-bit Open On-Chip Debugger 0.10.0+dev (2019-07-17-11:28)
Licensed under GNU GPL v2
For bug reports, read http://openocd.org/doc/doxygen/bugs.html
WARNING: interface/stlink-v2.cfg is deprecated, please switch to interface/stlink.cfg
Info : auto-selecting first available session transport “hla_swd”. To override use 'transport select '.
Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD
Info : clock speed 2000 kHz
Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Error: open failed
okay looked around saw that open error was because i did not have a win usb driver for the stmlink. used Zadag to install now this:
Info : STLINK V2J29S7 (API v2) VID:PID 0483:3748
Info : Target voltage: 3.139652
Error: init mode failed (unable to connect to the target)
I assume you cycled the 12V power after switching to DFU mode? Just make sure you did that, then check in Device Manager (on Windows, or lsusb on Linux). Please report your findings. If nothing shows up then it is possible it’s a defective board. Let me know.
yes i am cycling.
i get this in device manager:
Unknown usb device
Windows has stopped this device because it has reported problems. (Code 43)
A request for the USB device descriptor failed.
My USB cable (checked with other stuff) works, I am running Windows 10. After working with it last night I was able to flash the Odrive using the DFuSE software. However I never got the st-link v2 to work.
