Default configuration, dump_errors(odrv0), system: not found
Pretty new to odrive and I’ve been having quite a bit of trouble. Today I just decided to do an odrv0.erase_configuration() to get a fresh start and immediately ran dump_errors(odrv0) afterwards. Just wondering, is the “system: not found” message something to be concerned about?
In [11]: dump_errors(odrv0)
system: not found
  axis: no error
  motor: no error
axis1
  axis: no error
  motor: no error
Not really - it just means that your odrivetool version is newer than your firmware version, - the tool is looking for a feature that doesn’t exist in the old firmware, i.e. system-level errors. But it is otherwise behaving correctly. You can update the firmware easily with the odrivetool dfu command.
Thanks for the help! I tried running odrivetool dfu, but I got an “array index out of range” error:
and when I tried running the command again, I got a different error saying that “the device has no langid”:
I tried referencing the thread
but I’m still not sure how to solve this issue. I’m using Windows, unfortunately
I just saw the pinned message in the support channel on discord, will be trying that
Any luck getting it flashed?
Whoops super late reply, yep I got it working! Thanks so much
Question: My current Odrive isn’t dumping errors at all?
You have a mismatch between your odrivetool version and your firmware version.
pip install --upgrade odrive
odrivetool dfu
Thank you, I upgraded the odrivetool and everything worked
