I have a question about if it’s possible to use two different motors with the same odrive board. The main example is to use DUAL SHAFT MOTOR - D5065 270KV and ODrive Robotics D6374 - 150kv. The specs says that ODrive Robotics D6374 - 150kv needs 48 V and DUAL SHAFT MOTOR - D5065 270KV, maximum 32 V. Does the board regulate the voltages and bring to each motor the correct voltage?
Motors are usually current limited. Those voltages don’t really matter. Yes, you should be able to use those two motors with the same ODrive.
