Hi all,
I am trying to setup a hoverboard with odrive v3.6-56V by following every steps described below document.
https://docs.odriverobotics.com/v/0.5.5/hoverboard.html#hoverboard-motor-wiring
I found the pole pair as 52 by counting number of detents.
dev0.axis0.requested_state = AXIS_STATE_MOTOR_CALIBRATION was successfully done as
below motor setup shows
In [221]: dev0.axis0.motor
Out[221]:
DC_calib_phA: 1.9492510557174683 (float)
DC_calib_phB: -0.8201689124107361 (float)
DC_calib_phC: -1.12917959690094 (float)
I_bus: 0.0 (float)
config:
I_bus_hard_max: inf (float)
I_bus_hard_min: -inf (float)
R_wL_FF_enable: False (bool)
bEMF_FF_enable: False (bool)
current_lim: 10.0 (float)
motor_type: 0 (uint8)
phase_inductance: 0.0002176045236410573 (float)
phase_resistance: 0.17459237575531006 (float)
pole_pairs: 52 (int32)
pre_calibrated: True (bool)
requested_current_range: 25.0 (float)
resistance_calib_max_voltage: 4.0 (float)
torque_constant: 0.515999972820282 (float)
torque_lim: inf (float)
current_control:
Ialpha_measured: 7.879737854003906 (float)
Ibeta_measured: 6.309068202972412 (float)
Id_measured: 10.092523574829102 (float)
Id_setpoint: 10.0 (float)
Iq_measured: 0.178409144282341 (float)
Iq_setpoint: 0.0 (float)
Vd_setpoint: 0.0 (float)
Vq_setpoint: 0.0 (float)
final_v_alpha: 0.8792524933815002 (float)
final_v_beta: 1.6940604448318481 (float)
i_gain: 17.459238052368164 (float)
p_gain: 0.021760452538728714 (float)
phase: 2.700525999069214 (float)
phase_vel: 40.0 (float)
power: 26.511167526245117 (float)
v_current_control_integral_d: 1.7390443086624146 (float)
v_current_control_integral_q: 0.7940816283226013 (float)
current_meas_phA: -1.9550633430480957 (float)
current_meas_phB: 0.8230656385421753 (float)
current_meas_phC: 1.132250428199768 (float)
error: 0 (uint64)
fet_thermistor:
config: ...
temperature: 26.775304794311523 (float)
is_armed: False (bool)
is_calibrated: True (bool)
last_error_time: 0.0 (float)
motor_thermistor:
config: ...
temperature: 0.0 (float)
n_evt_current_measurement: 2181177 (uint32)
n_evt_pwm_update: 2181179 (uint32)
Now I tried to calibrate hall sensor polarity by calling
dev0.axis0.requested_state = AxisState.MOTOR_CALIBRATION.ENCODER_HALL_POLARITY_CALIBRATION
Motor turns a little bit and the encoder shows error: 16 as below
In [222]: dev0.axis0.encoder
Out[222]:
config:
abs_spi_cs_gpio_pin: 1 (uint16)
bandwidth: 300.0 (float)
calib_scan_distance: 520.0 (float)
cpr: 312 (int32)
direction: 0 (int32)
find_idx_on_lockin_only: False (bool)
hall_polarity: 0 (uint8)
hall_polarity_calibrated: False (bool)
index_offset: 0.0 (float)
mode: 1 (uint16)
phase_offset: 0 (int32)
phase_offset_float: 0.0 (float)
pre_calibrated: False (bool)
use_index: False (bool)
use_index_offset: True (bool)
count_in_cpr: 0 (int32)
delta_pos_cpr_counts: 0.0 (float)
error: 16 (uint16)
hall_state: 4 (uint8)
index_found: False (bool)
interpolation: 0.5 (float)
is_ready: False (bool)
phase: 0.0 (float)
pos_abs: 0 (int32)
pos_circular: 0.0 (float)
pos_estimate: 0.0 (float)
pos_estimate_counts: 0.0 (float)
shadow_count: 0 (int32)
spi_error_rate: 0.0 (float)
vel_estimate: 0.0 (float)
vel_estimate_counts: 0.0 (float)
I don’t know what is wrong with the above setup.
