The Calibration is stopping mid way when i change the encoder resolution and then the odrivetool stops working.
it gives me error 65.
Please make sure you’re running the most up-to-date firmware.
When fetching the error # in Python, please use the hex() function to format the errors correctly.
e.g. hex(odrv0.axis#.error)
We modified the encoder config and it started working, you can close this now, thanks for the help.
