I’m not really sure how to install the end-stop branch to my odrive with the DFU tool, since I don’t have an ST-Link.
My suggestion is to have ST-Link. Sometimes my ODrive wasn’t accessible after a shutdown. The only way to get it working again was to flash it with the ST-Link.
On the other hand, if you want to send ASCII commands, there is already the serial timeout bug. To do the workaround like described here: Serial Timeout Issue
you have to modify the firmware. With a ST-Link it’s much easier.
Greetings Zennix
I would really like to use this feature, but it still hasn’t been included in the main release. Can I help out with testing without an ST-Link, or is it too risky? If so, how? I have the hardware setup necessary to test end switches.
Please do help out! You’ll just have to pull the Endstops branch. I’m not 100% sure how to flash the firmware without an ST-Link, you can probably do some sort of DFU once you build the firmware though.
An STlink clone is stupid cheap. Like cheaper than the screw terminals on the ODrive.
$2.02 (US) free shipping on AliExpress
Less than $10 on amazon
I consider it pretty much a requirement to work with the ODrive.
Hi @Wetmelon
where can I download the V3.6 compatible version?
what GPIO’s are supported?
Is there a list of the specific commands?
cheers
Carelsbergh Stijn
Hello?
I need to finish my project, can you guys please help me?
Thankssssss
Cheers
Carelsbergh Stijn
Hi Stijn,
all you need to get it running with the end stop branch is documented in this thread.
Greetings / Zennix
Hi
Is there a v3.6 file available?
Do the switches need to be connected to 5v or gnd?
Are the switches NO or NC?
Cheers
Carelsbergh Stijn
Hi Stijn,
you have to use https://github.com/Wetmelon/ODrive/tree/Endstops
Switch against 3.3V. You can define high or low active. I had to use some capacitors on the GPIOs for preventing debouncing.
Greetings / Zennix
What USB driver do you have to use?
Cheers
Carelsbergh Stijn
My end switches are not recognized, what should I do?
Cheers
Carelsbergh Stijn
Hello
When I press the button, button state is false, when I don’t press the button, button state is false too, what can I do?
Hi Stijn,
This my config for an endstop that switches GND to GPIO 8.
odrv0.axis0.min_endstop.config
Out[37]:
gpio_num = 8 (int)
enabled = True (bool)
offset = -500 (int)
is_active_high = False (bool)
debounce_ms = 100.0 (float)
Greetings Zennix
Hi
Thank you, I’m now on vacation, I will try it afterwords.
Cheers
Carelsbergh Stijn
The Endstops branch has been updated to the most recent Devel HEAD. It compiles but I have no way to test, so please let me know if there are any issues.
Hi
I’ve updated it myself last week and it seems to work, I will try your version aswel
Cheers
Carelsbergh Stijn
Hi
What am I doing wrong?
After manual reboot it is not saved
Cheers
Carelsbergh Stijn
Hi Stijn,
odrv0.save_configuration()
and
odrv0.reboot()
Try this.
Greetings Zennix
