Hi, I have just got my new Odrive and I am trying to control the position of a motor. I have tried to do as the getting started documents says. But then, when I did the calibration I have got this error:
hex(odrv0.axis0.error)
‘0x41’
When I did calibration, there is beep sound and the motor does rotate, but only to one direction. Before I did the calibration I have check that the error was 0x0. Like this:
Strangely enough, after I have changed my pole_pairs into 0 the calibration works, but then when I do
the motor does try to fight me if i turned it by hand. But when I set new position, nothing happens and there is no error when i checked
What motor do you have? You should set pole_pairs to the correct value, not 0.
Can you reboot the ODrive, then run the calibration sequence of states that you wish to do. Between each step, can you check the hex(axis.error)? As soon as you have an error, check the troubleshooting guide on how to decode them. For example, you may need to query the motor or encoder error.
I have got alien power system aps6355s, and it has hall effect sensors. I have already tried to do speed control just like in the documentation bellow:
I have tried using a variable power supply before and it works. But then when I changed into another power supply the motor won’t move, even on calibration. I suspected that the power supply didn’t supply enough current to Odrive and the motor because it has current limiter of 3A. So, I would like to know how many amps do I need for the power suply?
I have a similar motor, Tenshock 812, I run it off of a 5a 24V power supply, but I have a large capacitor (5F 30V) in parallel with the motor. This helps the motor start (which generally requires extra amps) and helps overcome any other unexpected power dips.
The 5a powersupply is only enough for rudimentary testing. To actually use the motor I have a 100a powersupply, but batteries would be better.
I would like to know if my Odrive has failed. When I connect it to 24V the power light turns on. But when I connect it to my PC via USB my PC won’t detect ODrive. Is it possible that the Odrive has failed?
I have checked the output of 5V and 3.3V pin is correct.
