Hi, I have a BLCD 6384 motor with a hall sensor, but I can’t make it work, it turns a little and then stops, I already put the 47uf capacitors on it, and still someone still helps me.
Hi there 3D, in order to help you, the Dev’s may need a little more information; such as how the board is connected (wiring images) and a print out (screen) from Odrivetool maybe.
Hope this helps!
Regards Jerry
