I am trying to install following instructions on your website. Tried to install with pip and pip3. Error at bottom seams to deal with matplotlib?
tb0@tb0-desktop:/$ sudo pip3 install --upgrade odrive
(can’t post all the output because it contains links and new users can’t post more than two links in a post.)
Command “python setup.py egg_info” failed with error code 1 in /tmp/pip-build-jwox_xr4/matplotlib/
towen
July 24, 2021, 11:39pm
2
According to the internet, your python setuptools are out of date.
pip3 install --upgrade setuptools
I also had to do:
pip3 install --upgrade pip
I was able to upgrade odrive tool. Now my issue is in configuring. According to your documentation to set the control mode you first enter the axis and then controller. I think this might be backwards.
axis.controller.config.control_mode = CONTROL_MODE_VELOCITY_CONTROL
Should be:
odrv0.axis0.config.control_mode = CONTROL_MODE_VELOCITY_CONTROL
AttributeError: Attribute control_mode not found
