On @wetmelon / RazorsEdge branch, I notice that the error messages are broken. For example, I am currently getting:
In [488]: dump_errors(odrv0, True)
axis: no error
motor: no error
axis1
axis: Error(s):
UNKNOWN_ERROR!
ERROR_INVALID_STATE
ERROR_DC_BUS_UNDER_VOLTAGE
ERROR_DC_BUS_OVER_VOLTAGE
ERROR_CURRENT_MEASUREMENT_TIMEOUT
ERROR_BRAKE_RESISTOR_DISARMED
ERROR_MOTOR_DISARMED
ERROR_MOTOR_FAILED
ERROR_SENSORLESS_ESTIMATOR_FAILED
ERROR_ENCODER_FAILED
ERROR_CONTROLLER_FAILED
ERROR_POS_CTRL_DURING_SENSORLESS
ERROR_WATCHDOG_TIMER_EXPIRED
motor: Error(s):
UNKNOWN_ERROR!
ERROR_PHASE_RESISTANCE_OUT_OF_RANGE
ERROR_PHASE_INDUCTANCE_OUT_OF_RANGE
ERROR_ADC_FAILED
ERROR_DRV_FAULT
ERROR_CONTROL_DEADLINE_MISSED
ERROR_NOT_IMPLEMENTED_MOTOR_TYPE
ERROR_BRAKE_CURRENT_OUT_OF_RANGE
ERROR_MODULATION_MAGNITUDE
ERROR_BRAKE_DEADTIME_VIOLATION
ERROR_UNEXPECTED_TIMER_CALLBACK
ERROR_CURRENT_SENSE_SATURATION
ERROR_CURRENT_LIMIT_VIOLATION
I believe the error above should just be ERROR_CURRENT_LIMIT_VIOLATION.
I noticed there is a branch called ‘enable_large_enums’. I tried patching this in, but it doesn’t seem to make a difference.
https://github.com/madcowswe/ODrive/compare/sam_enable_large_enums
@Wetmelon any suggestions?
Cheers,
Tom
