Trying to connect to the ODrive board using odrivetool but getting “Task exception was never retrieved”. See full error message below.
future: <Task finished name=‘Task-3’ coro=<_Domain.run_discovery..loop() done, defined at C:\Users\LisaLi\AppData\Local\Programs\Python\Python38\Lib\site-packages\odrive\pyfibre\fibre\libfibre.py:974> exception=error(6, ‘GetConsoleScreenBufferInfo’, ‘The handle is invalid.’)>
File “C:\Users\LisaLi\AppData\Local\Programs\Python\Python38\Lib\site-packages\odrive\pyfibre\fibre\libfibre.py”, line 977, in loop
await callback(obj)
File “C:\Users\LisaLi\AppData\Local\Programs\Python\Python38\Lib\site-packages\odrive\pyfibre\fibre\shell.py”, line 41, in discovered_device
logger.notify(“{} to {} as {}”.format(verb, display_name, var_name))
File “C:\Users\LisaLi\AppData\Local\Programs\Python\Python38\Lib\site-packages\odrive\pyfibre\fibre\utils.py”, line 128, in notify
self.print_colored(self._prefix + text, Logger.COLOR_CYAN)
File “C:\Users\LisaLi\AppData\Local\Programs\Python\Python38\Lib\site-packages\odrive\pyfibre\fibre\utils.py”, line 112, in print_colored
self.print_on_second_last_line(text, color)
File “C:\Users\LisaLi\AppData\Local\Programs\Python\Python38\Lib\site-packages\odrive\pyfibre\fibre\utils.py”, line 78, in print_on_second_last_line
info = self._stdout_buf.GetConsoleScreenBufferInfo()
pywintypes.error: (6, ‘GetConsoleScreenBufferInfo’, ‘The handle is invalid.’)
I’m able to update the firmware on the board using odrivetool dfu since I’ve read some other forum posts suggesting that a firmware update might be necessary. However this did not solve the issue.
ODrive control utility v0.6.2.post0
Website: https://odriverobotics.com/
Docs: https://docs.odriverobotics.com/
Forums: https://discourse.odriverobotics.com/
Discord: ODrive
Github: https://github.com/odriverobotics/ODrive/
Please connect your ODrive.
In [1]: Task exception was never retrieved
await callback(obj)
I am receiving the same error. I’ve tried this on a different laptop as well and I’m getting the same error.
