ESP32 and CAN or not?
I am trying to setup CAN communication with an esp32-S2 and SN65HVD230.
No matter what I do, the compilation of the example SineWaveCAN fails.
I am using
  1. The definition IS_ARDUINO_BUILTIN
  2. ESP32S2 Dev Module in Boards Manager
  3. Espressif System version 3.3.3
  4. OdriveArduino version 0.10.6 from Feb 22
Are there any hints or is this a dead end?
“IS_ARDUINO_BUILTIN” is only for Arduino Uno R4. For ESP32, you may need to try this pull request someone made: Modified library for ESP32 native TWAI driver by BWV999-MTL · Pull Request #11 · odriverobotics/ODriveArduino · GitHub
Thanks.
However I can compile it now, but the setup does not work.
I have changed to UART.
