Hello, I’m fairly new to the Odrive products, I was using the Odrive for hoverboard motors, I have wired everything correctly and was able to get it to work. The problem is that only one motor (M0) was spinning and the other (M1) did not, if I restart, they both spin for a little but eventually one of them stops. I have modified the setpoint ranges on the PWM controller and both motors spin, unless I move one of them, the other stops.
odrv0.config.gpio3_pwm_mapping.min = -200
odrv0.config.gpio3_pwm_mapping.max = 200
odrv0.config.gpio3_pwm_mapping.endpoint = odrv0.axis0.controller._remote_attributes['vel_setpoint']
odrv0.config.gpio4_pwm_mapping.min = -200
odrv0.config.gpio4_pwm_mapping.max = 200
odrv0.config.gpio4_pwm_mapping.endpoint = odrv0.axis1.controller._remote_attributes['vel_setpoint']
odrv0.save_configuration()
odrv0.reboot()
I have changed this into 0 instead of -200 and 100 instead of 200. That’s how I got both of them to spin on bootup.
I’m using only one 36v Battery (I have another one now) and I have read the post on the capacitors but I don’t seem to need them. I also do not know what exactly Auxiliary does, but I would like to.
Thank you for trying to help me, I appreciate it. Here is a picture of the (Messy) Setup.
odrv0.axis0.motor.config.pole_pairs = 15
odrv0.axis0.motor.config.resistance_calib_max_voltage = 5
odrv0.axis0.motor.config.calibration_current = 5
odrv0.axis0.motor.config.requested_current_range = 25 #Requires config save and reboot
odrv0.axis0.motor.config.current_lim = 25
odrv0.axis0.encoder.config.cpr = 90
odrv0.axis0.encoder.config.bandwidth = 100
odrv0.axis0.encoder.config.ignore_illegal_hall_state = True
odrv0.axis0.controller.config.vel_integrator_gain = 0.1
odrv0.axis0.controller.config.vel_limit = 1000
odrv0.axis0.controller.config.control_mode = CTRL_MODE_VELOCITY_CONTROL
odrv0.reboot()
odrv0.reboot()
odrv0.axis1.motor.config.pole_pairs = 15
odrv0.axis1.motor.config.resistance_calib_max_voltage = 5
odrv0.axis1.motor.config.calibration_current = 5
odrv0.axis1.motor.config.requested_current_range = 25 #Requires config save and reboot
odrv0.axis1.motor.config.current_control_bandwidth = 100
odrv0.axis1.motor.config.current_lim = 25
odrv0.axis1.encoder.config.mode = ENCODER_MODE_HALL
odrv0.axis1.encoder.config.cpr = 90
odrv0.axis1.encoder.config.bandwidth = 100
odrv0.axis1.encoder.config.ignore_illegal_hall_state = True
odrv0.axis1.controller.config.pos_gain = 1
odrv0.axis1.controller.config.vel_gain = 0.02
odrv0.axis1.controller.config.vel_integrator_gain = 0.1
odrv0.axis1.controller.config.vel_limit = 1000
odrv0.axis1.controller.config.control_mode = CTRL_MODE_VELOCITY_CONTROL
odrv0.reboot()
odrv0.axis1.requested_state = AXIS_STATE_MOTOR_CALIBRATION
odrv0.axis1.requested_state = AXIS_STATE_ENCODER_OFFSET_CALIBRATION
odrv0.axis1.encoder.config.pre_calibrated = True
odrv0.reboot()
odrv0.config.gpio3_pwm_mapping.min = -300
odrv0.config.gpio3_pwm_mapping.max = 300
odrv0.config.gpio3_pwm_mapping.endpoint = odrv0.axis0.controller._remote_attributes[‘vel_setpoint’]
odrv0.config.gpio4_pwm_mapping.min = -300
odrv0.config.gpio4_pwm_mapping.max = 300
odrv0.config.gpio4_pwm_mapping.endpoint = odrv0.axis1.controller._remote_attributes[‘vel_setpoint’]
odrv0.reboot()
odrv0.axis1.config.startup_closed_loop_control = True
odrv0.reboot()
Also I had had issue with one of motor socket - contact was not good and at high current Odrive stops with error - bad motor resitance. So I just cut motor connectors and use bare wires.
I’ll check it out soon, thank you so much
Hello, I ran these and now they would not spin at all, what could this mean?
Note: I am using only one 36v battery, I do not know if it makes a difference to make it more.
Hi, Ahmad.
Script should be execute in this way - execute first part from begin to odrv0.reboot().
odrv0.reboot()
Than wait til connect to odrive restored and execute next part till next odrv0.reboot().
Wait till odrve beeeep.
Check wheels not blocked and no load applied. Than :
Wheel should slowly rotate forward and backward.
odrv0.reboot()
Repeat 4 times in same way.
If wheel not calibrated or not rotate in calibration phase please post output of dump_error(odrv0)
