I’ve just received an Odrive board and I’m eager to try it out. I supplied 48V to the board, connected the board to my PC through a USB cable, ran the odrivetool but it seems to me that Windows cannot detect the board. The board I’m using is v3.5.
I tried googling for solution, until I came across this post:
https://discourse.odriverobotics.com/t/odrive-3-5-not-recognized-by-windows/785/7
I followed what the guy from the post did, and all was fine until I faced an error that he never faced before. While trying to flash the firmware to the board, the odrivetool gave an exception during the flashing process:
(C:\ProgramData\Anaconda3) C:\Users>odrivetool dfu C:\Users\dsyiauw\Downloads\OD
riveFirmware_v3.5-48V.hex
ODrive control utility v0.4.1
Waiting for ODrive...
DFU mode is not supported on board version 3.4 or earlier.
This is because entering DFU mode on such a device would
break the brake resistor FETs under some circumstances.
Warning: DFU mode is not supported on ODrives earlier than v3.5 unless you perfo
rm a hardware mod.
Do you still want to continue? [y/N] y
Found ODrive 365733593037 ([unknown version]) with firmware [unknown version] in
DFU mode
You are about to flash firmware [unknown version] which is the same version as t
he firmware on the device ([unknown version]).
The configuration cannot be backed up because the device is already in DFU mode.
The configuration may be lost after updating. Do you want to continue anyway? [
Y/n] y
Erasing... done
Flashing... (sector 0/6)
C:\ProgramData\Anaconda3\Scripts\odrivetool in <module>()
140 print_version()
141 import odrive.dfu
--> 142 odrive.dfu.launch_dfu(args, logger, app_shutdown_token)
143
144 elif args.command == 'liveplotter':
c:\programdata\anaconda3\lib\site-packages\odrive\dfu.py in launch_dfu(args, log
ger, cancellation_token)
448 firmware = FirmwareFromFile(args.file) if args.file else None
449
--> 450 update_device(device, firmware, logger, cancellation_token)
451
452
c:\programdata\anaconda3\lib\site-packages\odrive\dfu.py in update_device(device
379 for i, (sector, data) in enumerate(touched_sectors):
380 print("Flashing... (sector {}/{}) \r".format(i, len(touched
_sectors)), end='', flush=True)
--> 381 dfudev.write_sector(sector, data)
382 print('Flashing... done \r', end='', flush=True)
383 finally:
c:\programdata\anaconda3\lib\site-packages\odrive\dfuse\DfuDevice.py in write_se
ctor(self, sector, data)
185 status = self.wait_while_state(DfuState.DFU_DOWNLOAD_BUSY)
186 if status[1] != DfuState.DFU_DOWNLOAD_IDLE:
--> 187 raise RuntimeError("An error occured. Device Status: {!r
}".format(status))
188
189 def read_sector(self, sector):
Can anyone please advise on what I can do to flash the firmware successfully?
