dbddqy
August 16, 2021, 4:49am
I’ve been trying to identify 3 different odrives by checking their serial numbers. However, I have problem reading the serial numbers with ASCII protocol. I sent
"r serial_number\n"
and received
"lu\r\n"
no matter which board it is.
I know it is quite simple in python by just
odrv0 = odrive.find_any(serial_number="XXX")
but I am working in c++. How should I do it?
lu is a formattting code (unsigned long). But you need %lu. Did someone forget a % somewhere in your code?
towen
August 17, 2021, 7:28am
3
What version of the firmware are you using? Is this an ODrive purchased from the official shop, or one of the fake ones?
You can also try the i command to get the serial number.
dbddqy
August 17, 2021, 8:50am
4
Thanks towen! The i command returns me the correct serial number!
