We’re having problems adding additional config variables to be stored in NVM.
I’ve trying to add 2 floats to either Axis config_t or Controller config_t to set up some soft limits:
In Controller.hpp:
struct Config_t {
ControlMode_t control_mode = CTRL_MODE_POSITION_CONTROL; //see: Motor_control_mode_t
float pos_gain = 20.0f; // [(counts/s) / counts]
float vel_gain = 5.0f / 10000.0f; // [A/(counts/s)]
// float vel_gain = 5.0f / 200.0f, // [A/(rad/s)] <sensorless example>
float vel_integrator_gain = 10.0f / 10000.0f; // [A/(counts/s * s)]
float vel_limit = 20000.0f; // [counts/s]
//bool test = false;
float pos_limit_max = 58368.0f;
float pos_limit_min = 3072.0f;
Also added definitions:
make_protocol_property("pos_limit_max", &config_.pos_limit_max),
make_protocol_property("pos_limit_min", &config_.pos_limit_min)
I’ve also tried incrementing config_version in nvm_config.hpp
Compiles and flashes fine but the odrive falls over, wont start/get detected. I have to DIP into DFU to reflash.
I feel like im missing something simple here…
Do i need to clear NVM (odrv0.erase_configuation() )before flashing?
Weirdly i added a bool property to BoardConfig_t which works fine, without incrementing config_version…
(edit: formatting)
