I got a error message,when “make” (ubuntu)
I also got an error when I used git bash
detailed message I don’t kown what cased the error. Please let me know if you have suggestions. Thanks
Are you using the same shared directory for Windows and Ubuntu? It seems like your Windows tup version is slightly different from the Ubuntu tup, thus causing this issue. Try deleting the .tup and build directories in the Firmware directory.
The error on Windows is unrelated (tup succeded here). Did you install OpenOCD?
You are right! It was caused by OpenOCD installation error.I have reinstalled it. Thank you very much!
