Hello! I have been just learning how to use the ODrive, reading up on forums and have been running into this problem with calibrating my motor.
Here’s the motor I’m using - X8318S KV100 KV120 Brushless Motor High Power High Loading Motor for Large Hexacopter Octocopter Agricultural Drone HLY W9235|motor for|brushless motormotor brushless motor - AliExpress
Here’s the encoder - AS5047P (digikey)
After I run odrv0.axis0.requested_state = AXIS_STATE_FULL_CALIBRATION_SEQUENCE, the motor only moves one direction then stops. Here are the dump errors:
system: not found
axis: Error(s):
UNKNOWN ERROR: 0x00000100
motor: no error
encoder: Error(s):
ENCODER_ERROR_CPR_POLEPAIRS_MISMATCH
axis1
axis: no error
motor: no error
After reading up on this I tried shadow count to make sure my encoder is working and I do get proper values for It. Any clue where to go from here. Thanks for all the help!
