Hi all so
I hooked up my odrive to a D50625 with the 8192 encoder kit.
I have reflashed it with the latest firmware.
I am starting with one motor and a 300W 24V psu.
After boot I can call the following
the motor does its stuff OK
then if I call
odrv0.axis0.requested_state = AXIS_STATE_CLOSED_LOOP_CONTROL it locks solid
odrv0.axis0.controller.pos_setpoint = 10000 usually works the first time
then calling
`odrv0.axis0.controller.pos_setpoint = 0 sometimes works
then after usually less than three repeated calls to pos_setpoint = 0 and 10000 it doesn’t move
called the cal function then no longer works
I have to call reboot and start again ?
Any ideas ?
Reconnected to ODrive 206A3366304B as odrv0
In [21]: odrv0.axis0.requested_state = AXIS_STATE_FULL_CALIBRATION_SEQUENCE
In [22]: odrv0.axis0.controller.pos_setpoint = 10000 (nothing happens as expected)
In [23]: odrv0.axis0.requested_state = AXIS_STATE_CLOSED_LOOP_CONTROL
In [24]: odrv0.axis0.controller.pos_setpoint = 10000 (This works)
In [25]: odrv0.axis0.controller.pos_setpoint = 10000 (This works as a test no movement)
In [26]: odrv0.axis0.controller.pos_setpoint = 5000 (this works)
In [27]: odrv0.axis0.controller.pos_setpoint = 50000 (this works)
In [28]: odrv0.axis0.controller.pos_setpoint = 5 (nothing happens)
In [29]: odrv0.axis0.controller.pos_setpoint = 0 (nothing happens)
In [30]: odrv0.axis0.controller.pos_setpoint = 50000 (nothing happens)
then needs a reboot before the cal will run.
I dumped errors and got
In [21]: dump_errors(odrv0)
axis: Error(s):
ERROR_CONTROLLER_FAILED
motor: Error(s):
ERROR_CONTROL_DEADLINE_MISSED
controller: Error(s):
ERROR_OVERSPEED
axis1
axis: no error
motor: no error
Peter
