Hello all,
I’m trying to get a 24V odrive to work with a Maxon 500269 Brushless Motor with embedded hall effect sensors. As was detailed in another forum post about getting hoverboard motors to work with hall effect sensors, I set the encoder to hall effect mode, and the CPR to 66 (6 * 11 pole pairs). However, every time I try to calibrate the motor, it stops after the forward rotation, and throws a CPR out of range error. I experimented with numerous other CPR combinations just to check (11, 6, 33, 3), but all of them kept throwing the same error. Can anyone help me with this?
