Has my board burned out?
I think my Odrive Mini board has burned out… and I don’t know why…
Let me give you some background.
I’m building a hoverboard with a motor, and I’m using an MKS Odrive Mini…
I’ve installed the wiring and flashed the firmware, which you may be familiar with, “FFbeast.”
When I first started it up, it seemed to work, but now I’m not sure at all, because when I start it up, I hear a crackling noise, and it doesn’t give me a good feeling, so I stop it immediately.
I’m not sure about that noise, as if something is burning. I hear it as soon as I start it up.
I’ve checked that the polarities on the power supply are correct.
What tests can I run?
How can I tell if the board has burned out?
Unfortunately those MKS boards are a knockoff of ODrive products, and are usually made with pretty poor design and quality control. I’d probably recommend reaching out to the manufacturer for a replacement.
I understand…
Where i can but official one?
In Spain or near?
We have a shop that ships from the Netherlands to all EU countries! https://eu.odriverobotics.com/ The ODrive S1 is likely what you’re looking for.
